Question about LG Washing Machines
My washing machine was working fine yesterday, tried to wash today and it is flashing pe. Tried to spin only and it starts then stops and flashes pe again. What is wrong?
  • LG Master
  • 12,061 Answers
"PE" Pressure sensor error. Cause: the sensor switch assembly is out of order.
You will need to replace your pressure sensor.
Either obtain a service manual for your exact make and model, or call an authorised service center and ask for a 'Quote" for the job.
Posted on Oct 06, 2010
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Nov 04, 2012 | Whirlpool Washing Machines
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
I have got Indesit WIXL 123 washing machine. Until yesterday, it was working fine. But today, when I started it, just after taking water and 5 initial spins, its Door Lock LED and 4th Function Button...
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Oct 26, 2009 | Indesit W 123 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
174 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
