Question about Dryers
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the touch, but the heating element that you can see inside the dryer does not appear to be on. We are to the point that we must unplug dryer after use because of fire hazard concerns.
  • Anonymous Mar 22, 2014
    dryer spontaneously heats and will not stop. Fire hazard worries
  • 525 Answers
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
Posted on May 28, 2008
Top of GE drier hot
When the dryer gets toward end of cycle, the timer will cycle off the heating element. (last 5 - 7 minutes.) This function takes place thru a resistor located near the timer switch, and parallel with the heating element. If this resistor fails, the heating element stays on during the cool down period. The resistor can be checked with a meter. If it doesn't ohm out at 4500 ohms, replace the resistor... Make sure power is off at the appliance when you check for resistance.
Jun 23, 2014 | GE DBXR463EDWW Electric Dryer
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer is spinning but doesnt have any heat
Has zero heat or just warm? Does it get hot then cool off? There are three safety devices in this model that shut the element off. If that isn't the problem then it is the element itself.
Jan 29, 2011 | GE DBXR463EDWW Electric Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Replaced heating element, now i turn on high heat and heating element stay on for only a minute
check for blocked air flow as this can cause limit switch to cycle early. go to sears.com for diagram.
Mar 02, 2010 | GE DPSR483EA Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer Overheating
your element should shut off when dryer is not running.their is a short somewhere.could be timer or even the motor switch.
Mar 11, 2009 | GE Spacemaker Washer and Dryer Electric...
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
