Question about Fisher and Paykel (IWL12)
Hi my f&p smart drive machine wont progress to next cycle and power keeps dropping out, no code signal is obvious, what do you think.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.From the information in your posting you mentioned that the machine would not progress to the next cycle because it turns itself off,Is this correct? Does the machine drain the water?Please reply with the additional information on the questions as I have seen this fault before but the additional information from you will confirm my suspicions.Looking forward to your reply.
Posted on Oct 06, 2010
  • brentnatalie Dec 30, 2010
    the same thing is happening to my smartdrive 701, if there is water in it, it doesnt drain. It just stops and beeps.
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
On power up the computer shows the windows screen and then will freeze with the progress bar stopped. It will stay like this until the machine is powered off by holding down the power button. Next it...
Hi
If it freeze and error codes comes out, It might be defective RAM MEMORY. Just replace new RAM memory card.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Jun 01, 2011 | Computers & Internet
F & P excellence 6.5 smart drive - Model GW608U - the machine will not fully progress throught the "Rinse" cycle. It will empty the wash water and spin & spray a little, then power...
Hi - this sounds more likely to be a faulty motor control module, its overheating and a electronic component is failing. Only way is to fit a new control module to eliminate the possibilty, another probable cause may well be the RPS sensor failing as it goes into spin mode.
Really need to do a few tests with a multi-meter, see if the motor/stator windings are ok, a faulty RPS at times will give a similar head ache..
May 05, 2011 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
Kelvinator Smart Drive 058 and I think the filter needs clearing
Hi there.... I don't have a solution but we have the same problem! If anyone is reading this and know the answer, you'll definitely be helping two people out!
Jan 28, 2010 | Fisher Washing Machines
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Power on washcycle won't start and light just blinks
Hi I have a GW708U Model. The lights on the display panel come on and then nothing happens when you hit the Start button. Any suggestions welcome.
Aug 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
135 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
