Question about HP Computers & Internet
My hp beeps and shows a black screen when trying to start up
  • HP Master
  • 7,733 Answers
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Posted on Oct 06, 2010
Is there a DOS BIOS that I can rescue for that model. If I go to HP site they only show Winbios that of course you need to do under windows.
As it beeps at you with no RAM, the bios is probably OK as is the processor. I would get the GPU re-balled.
Feb 20, 2015 | HP Computers & Internet
Beeps ram, blue screen, black screen
http://www.computerhope.com/beep.htm
READ THIS FOR SAME HELP.
IT IS PROBERLY THE RAM AND VIDEOCARD NEEDS ADJUSTMENT.
Dec 16, 2013 | HP Pavilion s7600n PC Desktop
HP a6500f will not come on...no HP Logo...no beeps...black screen...fans run
if u have system mechanic, you can use the disc to boot from and it'll read your MBR....it is probably messed up....and needs to be repaired. Have you ever used a registry cleaner? if not, you also may have tons of registry errors....and registry errors can also give you blk screen of death.if you have no system mechnic disc nor can borrow one, then try this.....http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
please post back you findings
Apr 22, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
Hp omnibook xe4100 repeated beeps then black screen comes out. to start my laptop i press esc button before the beeps comes then esc again till i see mya windows
Try reseating the memory cards in the notebook to make sure they have a good connection.
if they lose connection you will get a black screen.
Jun 26, 2010 | HP Pavilion dv6000z Notebook
All I get is the hp invent black screen. computer
Try flipping it over, unscrewing the back panels and pop them off. Take out 1 stick of memory if there is 2, or take all memory out. Then try to turn it on. It will either do nothing but turn on and beep, or it will turn on but show nothing on the screen. Then shut it off and put the memory back in. Sometimes this kind of reset gets past that bios screen. Otherwise your memory may be bad. The other culprit can be the battery. Try removing the battery and starting it with it plugged into the wall. Let me know if this fixes your issue.
Apr 30, 2010 | HP Compaq nc6320 Notebook
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
When I turn it on I get three beeps and nothing else
The 3 beeps are correct diagnosis for the screen problems.
reboot, keep tapping F8, till you get to
the start up screen ( black dos screen )
Try the last known good first at the top, let it roll.
If this fails, try safe mode, let it boot up, then try a system restore,
start,all progz, accessories,system tools,system restore, try go back in time.
If you cannot get into the "black" start up screen at all, your video card, has failed.
because you should get minimum of VGA graphics in safe mode.
if you do, then the video driver is corrupted and needs updating
Regards
Richard.
Apr 24, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
152 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
