Question about SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal
Was working fine and no it looks like it loads into the computer but when I look to open its not there
  • 358 Answers
Even though it is possible that your USB hard driveis corrupt, but
before you finally conclude, try out these few troubleshooting
steps.
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
goes
Hope this helps you out.
Thank you for using Fixya
Goodluck
Posted on Oct 07, 2010
How do i get my netflix app to open on my laptop?
In my opinion you should contact customer service for Netfix, they can help you start, do not think it's a problem of your computer
Jul 31, 2014 | ASUS Computers & Internet
My scenic w600 i865g have worked just fine until I moved the computer to another place in the room, the computer shuts down when windows are loading it's the same when loading unix that is on a...
If the problem disappears when you move the computer back to the previous location, it's most likely something in the new location that is causing the problem. Could be a bad power outlet or some heavy duty electrical interference.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 26, 2011 | Fujitsu Siemens SCENIC W600 PC Desktop
The dvd drive on dell inspirion 1525 wont open...when I go to it under computer it says please insert dics and then say failed to eject...what do we do??????????
The loading tray has a pin hole on the front door, get a fine screwdriver or needle and push it in until you hear a click the tray should pop open, pull it all the way out, look under the tray for a small black loading belt make sure it is snug tight. If the DVD driver fails to work at this point, replace the entire assembly.
Jan 08, 2011 | Dell Inspiron 1525 Notebook
Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Jan 26, 2010 | Visioneer OneTouch 5820 Flatbed Scanner
Nokia 6300 Camera: slow loadup, slight haze, slow exit
i had the same problem and was looking for answers as to your questions. mine was cam loading and getting ready to take next pix was about 11 secs,,,i just cleared the memory,,viz moved almost all vids and pix to computer and it is fine now,,,,i have a 1 gb card in it and it was almost full upto 900mb+
Sep 06, 2009 | Nokia 6300 Cellular Phone
I loaded my 3150 on a back up computer. It worked fine on my other computer. I used the disc to load it. It will print but will not scan or copy. My computer defaults to the 3150 for scanning and printing...
You need to look back on the driver settings for the scan options. Compare the driver options on the computer that is working fine and note any difference and correct it accordingly.
Jul 09, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lost instructions how do i get the pics off the camera
Ok, I looked all over for the instructions. But there aren't any. I can give you a generic method, but it will only work if you have the driver installed. I'm going to assume you do.
Turn the camera off (if it in fact has an off button).
Plug the camera into your pc.
Turn the camera back on.
Go to My Computer and look for it in the removeable drives.
If it's there, double click on the drive and drill until you find your pics.
Good Luck!
Rb
Mar 05, 2009 | Philips Cameras
Cannot get facebook page to open, all others open, home computer
Try going to http://m.facebook.com and see if it works.
Nov 30, 2008 | HTC G1
Computer Games - Problems loading games on fully loaded system.
Try to find system recruitments for the games and then check if they fit with you PC configuration
Instal the newest wersion of DirectX
May 26, 2008 | Intel Computers & Internet
SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal Logo
54 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
