Question about Dell Dimension 3100 PC Desktop
Good day to you. I have a dell dimension 3100 PC and when i press the power button, the power light constantly flashes and it does not boot up. No sound either. Nothing happens.
How old is this machine? It sounds like a power supply issue. If you have a different PC you could try and swap power sypplies.
Posted on Oct 06, 2010
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dell dimension 3100 restarting
This is generally an indication of boot failure , often as a result of new hardware addition or new software installation. Try pressing the F8 key repeatedly (about once per second) while booting and boot in safe mode. If no success , try removing any hardware (especially flash drives) that was added since the last time the machine worked and try the above again
Jan 05, 2014 | Dell Dimension 3100 PC Desktop
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Working on dell dimension 3100/e310 desktop pc. when u press the power button u get a soid green light with beeps and the diagnostic light are green on lights numbered 3 and 4. need help badly
Constant beeping on power up can be a memory issue.
Locate the memory module and reseat it by taking it out and putting it back. Do this with the battery and power adaptor out. The module is normally located under a cover on the base of the computer.
Feb 19, 2011 | Dell Dimension PC Desktop
I have a Dimension 3100 everytime I turn on tower an orange light comes on Please help???????
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 won't start.
Check to see if the monitor cable is connected properly.
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Computer not coming on
Flashing Amber Light on a Dell Desktop is a defective power supply.
You can get a replacement from various vendors, or Dell.
Good Luck.
Feb 26, 2009 | Dell Dimension 3100 PC Desktop
No power up no post no nothing on dimension 3100
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. It sounds like you have isolated the problem to the motherboard since you removed everything but the board and power supply. You may be able to locate one by browsing the internet. Just type in “DELL Dimension 3100 motherboard” and see if you can locate one at a reasonable price.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You
Sep 27, 2008 | Dell Dimension 3100 PC Desktop
Dell Dimension 5150 PC
this sounds like a motherboard fault, the green light shows power to the board but the orange can indicate that the board has failed
Sep 15, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 3100 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
