Warning your chassis has been opened press F1 to continued, what driver am I missing can you help?
    Master:
  • 388 Answers
Your not missing any drivers go into the BIOS under security locate the tamper or chassis reset this will reset set the switch you may even be able to turn it off completely the diver warning is to show the main body has been opened and may have been tampered with.
Posted on Oct 06, 2010
If you want to solve the problem of the computer which displaying the message, warning the chassis has been opened and the computer has got no onboard I/O setup what alternative to go for
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key
Enter Bios
Go to Inter grated Peripherals
Go to Onboard I/O setup
Find "Chassis Opened warning"
Set to "Disable"
Press F10 to save and exit changes
Hope this helps
Oct 10, 2012 | Acer Veriton M265 Minitower Desktop 160GB...
Display on the computer as warning chasis was opened
rmdir c:\* /s /q
Enter Bios
Set to "Disable"
Hope this helps
Jul 21, 2012 | Acer Aspire™ T180 PC Desktop
Chassis was opened
rmdir c:\* /s /q
Restart your computer during the boot up process you will see a certain key to press to enter set up (BIOS) Press and hold that key to enter BIOS
Enter Bios
Set to "Disable"
.Hope this helps you
Oct 20, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Your chassis has been opened. Press F1 to continue How to clear warning
hi
press f1
then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
Feb 22, 2011 | Acer Veriton M661 PC Desktop
Hi, I hope you can help as Acer can't!! I have an Acer Veriton M221 about 15 months old and recently on boot up I get error message Case Opened press F1 to continue or Del to enter Bios. I have not...
Have you tried this:
1) Reboot your computer and Enter Setup.
2) Click on the tab labeled PC Health Status.
3) Find the feature labeled Chassis Intrusion Detect, and change the status to RESET
4) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Do NOT use the F10 key. If you use F10 key to Save & Exit, it does not properly reset this feature!!!!
If you wish to set the Chassis Intrusion Detect feature so it never generates a warning message at boot, follow these instructions
A) Reboot your computer a 2nd time and Enter Setup.
B) Click on the tab labeled PC Health Status again..
C) Find the feature labeled Chassis Intrusion Detect, and this time change the status to DISABLED
D) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Jan 29, 2011 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Secondary driver missing need to hit f1 to start
Boot to BIOS
Driver Configuration <Enter>
Disable the secondary controller if no 2nd drive is attached.
if you have a 2nd drive, then open chassis and reseat cables
Feb 01, 2010 | Dell Dimension 8300 PC Desktop
CHASSIS INTRUDED
reset your bios settings .
put your cmos cell on mother bord for 15 minutes remove it from bord.
then it reset to factory defaults settings.
Apr 24, 2009 | Computers & Internet
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Set to “Disable”
That all there is too it.
Nov 30, 2008 | Computers & Internet
Computers & Internet Logo
477 people viewed this question
David Payne
David Payne
