Question about Nikon N6006 35mm SLR Camera
I have trouble taking indoor (low light) photos. pictures come out blury and the camera does not snap the picture properly i have a nikon 35 mm n6006 camera
  • kakima Oct 06, 2010
    What do you mean by "not snap the picture properly"? is the exposure coming out wrong? Or is the shutter speed simply longer than you want?
    The main problem is that it's a low-light situation. In order to get enough light to properly expose a picture, the lens has to gather light, the shutter has to open long enough, and the film has to be sensitive enough.
    The wider the aperture, the more light passes through the lens. Set the largest aperture (smallest f/number) you can on the lens. If you can, use a "faster" lens.
    If the shutter speed is too long for you to hold the camera steady, use a support of some kind. A tripod or monopod, or rest the camera on a table or against a wall, or brace yourself against a wall.
    Use a faster film, if you're not already doing so. The higher the ISO rating of the film, the more sensitive it is to light and the more suitable for low-light situations. They won't work as well in bright situations, like midday sun, however.
    Another possible solution is to add light, such as using a flash. This won't work if the subject is far from the camera, as at a concert or a night ball game.
  • 26 Answers
Hi Rebecca--
The hardest thing about low light photography is balancing your available shutter speed to the amount of action you're trying to capture.
Here are a few things to try:
1) Try using a tripod. Steadying your camera during long exposures will greatly improve your image clarity.
2) Buy a faster film. You may need to increase your film's ISO setting. Try 400 to start, then go up from there. Remember, faster film always produces grainy images, and it usually costs a little more to process. If you're stuck with 100 ISO, you can always "push process" the film, where a given ISO is let to sit in its developer longer than usual--This will cost you more too!
3) Invest in a good flash system. Nikon has tons of hotshoe flash systems that rarely compromise the ambient light-mood of a given situation. Look for one that lets you aim the flash in different directions, and try to find one that will meter a light situation on its own.
4) Turn on the lights. If you're ok with losing some of the romance of an image, turn on some more lights to give you some more flexibility when making your exposure choices.
5) Open up your aperture. You may find that a lot less in depth of field will give you a lot more in image clarity and exposure flexibility. Shooting at f2.8 with only a birthday cake lighting your subject will grant you many more valuable shutter stops that shooting the same with f5.6.
Remember, Rebecca, if you're shooting handheld, you must do everything in your power to shoot with the quickest shutter speed available. This will cut down on the blurriness of your indoor images.
--Hope this helps.
Posted on Oct 07, 2010
My pictures are constantly coming out blury...I have it on sport mode, what else should I be checking.
Blur is usually caused by one the following problems. 1) Camera is unable to focus so the shot is out of focus. 2) The hand shakes during a shot that has a longer exposure (shutter speed) and 3) There is not enough light so the camera holds the shutter OPEN (seeing) while to subject is moving. In most cases you will have few problems when you have plenty of light. Many indoor areas when you zoom in have too little light to take a quick non blurry photo.
Flash can freeze motion. The flsh is quick and it is like a strobe freezing action. A tripod prevents camera shake.
Nov 08, 2013 | Nikon Inc Nikon Coolpix S9050 - digital...
What lens can I use the the Nikon N6006 35 mm SLR Camera?
The Nikon N6006 will use just about any Nikon F-mount lens made in the past 55 years. About the only exceptions are some rare (and very expensive) fisheye lenses and the newer DX lenses specifically designed for digital cameras.
Jan 11, 2013 | Nikon N6006 35mm SLR Camera
How do i snap a picture?
Press the shutter release button located atop the handgrip.
There are restrictions, depending on the lens and the exposure mode. If you need a manual, you may download a copy from here.
Sep 28, 2012 | Nikon N6006 35mm SLR Camera
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blurry indoor photos
blurry pictures often comes from the slightest movement when the pictures is snapped.
Don;t know if that is your problem or not try a photo tripod and see if that helps or check your trouble shooting area of your amnual. if you don't have the manual go to this site for any type of manual::::
http://tv.manualsonline.com/search.html?q=vr+5940&submit.x=35&submit.y=14
Aug 28, 2009 | Cameras
Pictures are blurry.
Try pressing the shutter button half way to let it focus before you shoot. You also may want to make sure the camera is in auto mode and not set to any particular setting.
May 09, 2009 | Nikon COOLPIX S60 Digital Camera
NIkon D60 - blury lens
for the close up photo u have to use micro or close lens set
Apr 25, 2009 | Nikon D70s Digital Camera
Blury and dark pictures
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 11, 2007 | Nikon COOLPIX L4 Digital Camera
The subject is very blury or out of the picture
You are expecting too much for any auto mode. When shooting under low light conditions, the camera may take longer to achieve focus lock. If the subject is moving too, it will take even longer to lock focus. Try using manual focus for the conditions you described.
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
Nikon N6006 35mm SLR Camera Logo
96 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
