Question about Compaq Presario 5000 PC Desktop
Problems with dvd/cd drive
I am having problems with my dvd/cd drive. each time i put in a dvd or cd it won;t work. i orginally was removing programs with control panel (in hopes of speeding up computer due to alot of internet programs freezing). since that time, i have done restoring to a restoration point as well as an entrie pc recovery. both have given me no success in fixing this issue. i then tried to go into safe mode and uninstall, then install this driver as well as returning to default bios. still no result.
as such i;m curious as to if there is something else that can be done, or if it would just make more sense to get a whole new cd drive at the store
  • 77 Answers
If you put the dvd/cd in the drive and hear it spinning, it may not be the drive. Check your device manager to see if any drivers are missing. Right-Click on My Computer > Manage > Device Manager. If you see anything with a yellow ! or a red X than you may have a driver issue. If not, than it could possibly be the physical cables and/or connections. If you are comfortable enough to open up the case, try replugging in the drive at both ends to make sure you have a good connection.
If all else fails, it may have just been a coincidence that the drive failed when you did your cleanup. Disc drives are rather cheap these days too, so you don't have to worry about spending an arm and a leg on a new one. Let me know how you make out.
Chris
Posted on May 28, 2008
  • 55 Answers
Try to check the signal (i.e ide cable) cable and you make sure you did not didable it
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Cd rom on windows XP wont work?
how old is the computer cd rom might be time for new one
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 12, 2012 | Computers & Internet
Please help, my ''Slimtype DVD A DS8A3S ATA Device '' won't work.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
May 01, 2012 | Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
My cd-r/dvd-r rw, will not recognize blank discs. When it does recognize the disc, it burns at most two audio tracks and finalizes the cd. Then giving me an error message saying disk may be dirty or...
I suggest you try a better program. It is possible there is something wrong with your drive, but this sounds more like a silly software problem. If you are SURE you have a drive capable of burning, then try this free program. I have a blu ray player, it stopped working with most bluray discs. Found that I needed to update the firmware, but my Windows software couldn't burn an .iso disc. This software can do anything you need. http://cdburnerxp.se/download.php
It is free and works beautifully. I was able to download the program, burn an .iso disc and update my bluray player in minutes.
Aug 29, 2009 | Computers & Internet
I put a dvd in my dell inspiron 1150 combo dvd cd andit will not
Uninstall the program and reinstall it,
maybe the disk with the drivers will solve your problem,
if no disk download the drivers from www.dell.com
or try the manufacturer ofr the dvd drive for the drivers too
also what Service Pacxks do you have installed on this machine
XP will need at least SP2 for some of you high speed devices ie usb2.0
Good Luck MISTERDJ
Aug 16, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Cant install program from DVD drive GWA-4164b
do you use orginal CD or DVD. if you saying yes. your CD/DVD drive is getting break down
May 27, 2009 | Acer (4432A-002) CD-RW Burner
My nero vision wont detect my dvd burner drive
well relax there is no probleme with your dvd burner drive
1 Remove nero from your computer
2 Instal ashampoo burning studio
3 Burn anything you want
4 Dont forget to rate this ;)
5 Have a nice day
Apr 28, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
Acer Internal DVD RW Drive not working for "written" dvds.
The quality of the writable CD can make a big difference, and maybe run a CD driver cleaner as well.
Another thing to try is to write the CD at a lower speed, not the driver maximum, this can help with less quality CDs as well.
Jules
Apr 23, 2009 | Acer (91.AB264.023) Internal 32x CD-ROM...
Cd writer program
Reinstall the program if you have a stand alon copy, or it may be on an application disk that came with your system.
Apr 26, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Compaq Presario 5000 PC Desktop Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
