Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Tv shuts off
My pioneer 53 inch shuts off before right before it shuts off the sound gets loud and it doesn't come back on. I do have a satellite box attached to it and leave it on ocassionally
    Scholar:
  • 136 Answers
Remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
Posted on Oct 12, 2008
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer vsx-d850s Home theater help needed
well i dont know how much they differ but i have a vsx-517 reciever(pioneer) all i do is run the one video out to my tv and run everthing else through my reciever.my configuration is i have the tv/sat input hooked up to my dvd which has an video out and then my sat was hooked to dvr/vcr input hope this helps alo there is loudness setting and speaker configuratino as well i have my effect turned as far as they will go so i suppose it punches out fairly decednt volume at -60 through 35 any further and i sometimes overload my system lol anyway hope this helps if you need and idea on what it look like ill take a pic ans send it to you-z
Feb 18, 2009 | Audio Players & Recorders
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
SD-532HD5 TV shuts off when watching
Its is a cold solder joint on the board. The board is the one located at the bottom right of the tv when looking at the rear. Mine did the same thing. After refreshing mose of the large solder pints on the board, it stopped. Hope this helps!
Nov 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Audio problem with hitachi 53 inch rear projection t.v.
Good Day, 1bigmoney;
Try resetting the SAT box. To do this unplug box for 2 to 3 minutes then plug A/C cord back in outlet. If no fix have SAT. box replaced, after making sure all cables on BOX are secure.
Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Shuts off
sounds like the high voltage transformer
or could be high voltage off the tubes.
not a good idea to keep this running as it will cause more damage, best to have service tech look at this since it's high voltage.
Be careful. This same problem burned a mark in the Blue crt on my pro730HD. Three months and the Service Tech and Pioneer have been unable to determine the cause (they claim). In the process they have blown two more crt's.
When your tv goes off, try turning it back on using the main power button instead of the remote. The button should be behind a flip-down strip below the screen. When it is working again, look for any faint colored spots in the picture most prominent on light backgrounds. Mine is a yellow Y in the center of the screen.
If there are no spots, I would suggest you don't use the TV until you get it fixed because eventually it will damage your crt ($750). Of course, as I said, they have been unable to fix my problem and I have had no TV for three months.
Nov 21, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
46 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
