Question about Refrigerators
The interior lights have gone out only in the non-freezer side of my refrigerator. The freezer side interior lights are working fine. Also, the electricity is on and the refrigerator is keeping it's temperature.
  • wbkurth Oct 06, 2010
    i can't believe all three or four bulbs would go out at the same time so I assume it must be the door switch. how can I fix the door switch and where is it?
    there is no obvious door switch anywhere on this appliance. I think i'll have to get an expert to come to the house, because I can't figure it out.
    Genius:
  • 1,478 Answers
This is the most common of all freezer problems and a simple one to solve. Simply replace the bulb or check for the door switch.
Take care.
Posted on Oct 06, 2010
  • Jimoh Adeleke Muyideen Oct 06, 2010
    Locate the refrigerator light switch. This will vary depending on your
    fridge, but it has to be located in a spot where the door can compress
    it when the fridge is closed. The interior light in most refrigerators,
    and the fan in some, is controlled by a door switch. Locate
    the switch and remove it by removing the retaining screw (if
    any) or by prying it with a putty knife. Place a piece of
    masking tape over the blade of the putty knife to prevent
    damage to the refrigerator. Gently pull the switch from its
    housing and expose an inch or two of wire.
    The switch will be connected by two wires
    (four wires if it also controls the fan). Label the wire placement
    on the switch before disconnecting the wires. The wires are
    connected to the switch with slip on connectors. Firmly pull
    the connectors off of the switch terminals (do not pull on
    the wire). You may need to use a pair of needle-nose pliers
    to remove the connectors. Inspect the connectors and the terminals
    for corrosion. If the connectors are corroded they should
    be replaced.
    You can use the manual to locate the switch.
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
Freezer not sending cold air to the Frige area.
The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
((If the switch is ok, and it passes the test, simply replace the fan)).
Sep 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Fridge/freezer temp lights and interior light dont work
I found a repair diagram on the web that showed the parts picture and part number and saw the box in the back lower left corner of the refrigerator that housed the circuit board.
Jun 18, 2008 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
