Question about Albatron KX18DS Pro Motherboard
Usb one of usb back panel not working
Aaaa  tank u 4 this solution
Posted on May 29, 2008
Please check the other two USB panel, it may be dedicated or worked properly with lower versions of USB devises(v.1). Check BIOS also if necessary and USB voltage in your motherboard but please refer your motherboard manual. Hope this helps.
Imac G5 USB panel
Try eBay, lots of iMac spares, you might be lucky.
Jun 04, 2013 | Apple iMac G5 Desktop
ASUS CG5275 USB ports on back panel won't work
You might need the drivers, it's an odd case if they worked before.
Another possibility is the jumper header fell off the motherboard while you were moving it, this is most likely the case.
I hope this helps.
Feb 23, 2013 | ASUS CG5275AR003) PC Desktop
Dell dimension 2400 usb not working
Hello.
Your Dell has two front-panel and four back-panel USB 2.0 ports.
If NONE of the USB ports are working (and I'm figuring that you have tried other USB devices to eliminate a faulty USB device), this is usually caused by a drive letter conflict. The best way to resolve it is to remove all USB devices, then uninstall the USB controllers and hubs from Device Manager, then reboot and allow your controllers/hubs to reinstall.
If still a problem, use disk management to assign higher drive letters to the existing devices. For example, a permanently connected external hard drive and card reader can be set to V and W. Generally, newly connected flash drives will take the next available letter.
Hope this helps.
Jun 30, 2010 | Computers & Internet
500 GB HD stopped working
plz check the drive spin up when u connect to power
dont use front panel usb plz use back panel USB
Jun 26, 2010 | Buffalo Technology (USA), INC. - 500GB...
Icon won't appear on desktop.
It is possible that your USB flash drive is dead.
The other solution is to try it on some other USB port of your PC (if you used front panel USB ports now try it on the back panel).
If it also wont work, try to connect it to some other PC
If it works with an other PC, your USB ports are dead
You can try going to device manager, and to unintall USBs and reinstalling them
Nov 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PNY 4G USB 2.00 Flash Drive
Solution:
i) try connecting it on the USB port present at backside or back panel of your computer tower, sometimes USB port present on the frontel panel of your computer might malfunctione or not working properly........
Nov 20, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
Albatron KX18DS Pro Motherboard Logo
50 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
