Question about Maytag Microwave Ovens
How to fix the ignition for a Maytag gas range? One of the ignition is broken, other threes work fine. Any repair kit available? Thanks! Kevin
  • 857 Answers
Follow these steps :
•1
Locate and shut off the circuit breaker that supplies the current to the stove.
•2
Remove the burner grates, if you are replacing the stove ignitor. Remove the oven racks if the oven ignitor is being replaced.
•3
Remove the bottom of the oven, if the oven ignitor is being replaced. Do this by removing the screws in the corners and lifting out the bottom plate.
•4
Locate the ignitor, which is next to the pilot light for each ignitor. It will be secured with two screws and have two wires attached to it. It will look the same whether you are changing the oven or stove-top ignitor.
•5
Remove the two screws that secure the ignitor in place.
•6
Pull out the two wires that are attached to the ignitor. The wires clip onto the ignitor and can be pulled off by hand.
•7
Attach the new ignitor by screwing it to the surface where the old one was removed. Attach the wires by clipping them into the ignitor. Replace the bottom plate of the oven, if it was removed, and put the racks or burner grates back in place. Turn on the circuit breaker.
Posted on Oct 06, 2010
How to fix a maytag handle on a maytag microwave
Possibly three parts. Take it apart and look for the broken one.
Mar 05, 2015 | Maytag MMV5207BAW Microwave Oven
Have a maytag microwave #MAYMMC5000ADB SER # 0039UF that is 10 years old and broken. We have the trim kit that fits our opening Item # JM MK241B 24
Measure the opening and also the trim kit dimensions and go shopping for a new unit as 10 old ones rarely have parts available
Nov 05, 2012 | Maytag Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Maytag MGR5730BDW gas range oven do not bake, the automatic pilot turn on but burner bake don't start
heatman101
Jul 04, 2011 | Microwave Ovens
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 20, 2010 | Microwave Ovens
Our carousel doesn't turn anymore. What can we
You probably have a broken belt. You can get a new one at http://www.repairclinic.com . They also have diagrams which show how to take your unit apart and replace the belt. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Maytag Microwave Ovens
Dead microwave!
Hi Kevin
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If still you are unable to diagnose the issue then it is recommended to call a local repair center for this to get fixed as Microwave usually have high voltage even when it is turned off.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 24, 2009 | Kenmore 63672 Convection/Microwave Oven
TRIM KIT INSTALL
Phone these guys at maytag - sorry info is not available online 1-800-688-9900. Hope this helps :)
Mar 09, 2007 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
111 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
