Question about Panasonic PT-D3500U Multimedia Projector
Cannot access menu screen on Panasonic PT-D3500U projector
Good morning,
I cannot access menu screen on Panasonic PT-D3500U projector here work. Is there a way that this can be solved?
Thank you!
  • 4,234 Answers
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
Posted on May 28, 2008
Trying to setup the Panasonic PTL 720U, accidentally turned off the control key to OFF in the menu and now cannot access Menu or another other options. How do I reset back to factory or so I can access the...
In order to set the CONTROL KEY to "ON" without
using the remote control unit, keep holding down
the ENTER button on the projector and press the
MENU button for more than 2 seconds. It will then
be turned ON.
Feb 12, 2011 | Panasonic PT L720U Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes orange...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
If PT-D3500U lamp won't strike (bulb has been changed with no effect), how can you reset the lamp timer to get the unit operational?
Instructions are listed in the owners manual (http://service.us.panasonic.com/OPERMANPDF/PTD3500U.PDF) on pg. 46.
Press the "POWER" button (or the POWER OFF ( I )
button on the remote control) so that a picture is
projected onto the screen.
Press the "MENU" button to display the MENU screen,
and then press the and buttons to move the
cursor to select "OPTION2".
Press the "ENTER" button to display the "OPTION2"
screen, and select "SYSTEM INFORMATION" with the
and buttons.
Press the "ENTER" button.
The SYSTEM INFORMATION screen will be displayed.
Press and hold the "ENTER" button on the projector or
the remote control for approximately 3 seconds.
An item "LAMP TIME RESET" will be added.
Press the ENTER button, and when the "LAMP TIME
RESET" display flashes, press the ENTER button again.
The used hours of the lamp unit will be reset to zero.
Jan 14, 2011 | Panasonic PT-D3500U Multimedia Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
The projectors periodically go to a blue screen in the middle of a presentation.
are they hooked up to a laptop? we've had the same problem with that before. When hooked up to the laptop it goes to sleep or turns off. bringing up the blue screen. maybe change the settings in the computer.
Oct 17, 2007 | Panasonic PT-D3500U Multimedia Projector
Problem with Power up on PTD3500
Position reference device has probably fallen off the filter wheel, replace the filter wheel.
Sep 20, 2007 | Panasonic PT-D3500U Multimedia Projector
Panasonic PT-D3500U Multimedia Projector Logo
431 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
