Question about Car Audio & Video
I have a 2000 chevy venture and the radio it just locked pleae help me it is driving me crazy
    Scholar:
  • 60 Answers
Taken from:
http://autoforumz.com/Pontiac-Help-u...pict40505.html
GM DELCO THEFTLOCK RADIO UNLOCK CODE:
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
2. After doing step one and writing down the code, immediately press
the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over).
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if
you're
calling for Chevy, Pontiac, Cadillac, etc... When you here him tell
you
to press "2" for Pontiac, press 206010 and hit the # key. He'll ask
you
for the 6 digit code that you've written down. Enter that and press
the
* key. He will then give you a code, and the option to get additional
digit codes, but one should be sufficient.
4. Follow the normal procedure in your owners manual for unlocking the
radio with your new code...press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
the 4 digit code from the GM recorded message, just keep it in a safe
place, because you can use that same code again and again should you
have any more problems with it in the future. Good luck
Posted on Oct 05, 2010
2000 chevy venture won't crank with key
The pk3 system has a sensor ring around the lock cylinder these go bad a relearn will not fix this because no security code is being sent to the pass key module.
Mar 23, 2014 | 2000 Chevrolet Venture
Already replaced the MODULAR FUEL PUMP ASSEMBLY W/FUEL GAUGE SENDER in my 1997 chevy venture. fuel gauge is still going crazy.
gauge may be bad--car is 15yrs-the instrument cluster cud go bad and rebuild in order--if speedo goes-thats usually an indication---duble chec instalation on the pump-wires etc-view a repair manual--mite want to unplug computer then replug
Oct 28, 2013 | 2000 Chevrolet Venture
How do I unlock the radio in my 2000 chevy venture ONLY SAID LOCHED
You need to contact local Chev dealer and provide your VIN# and they can give you code for your radio.
Mar 22, 2011 | 2000 Chevrolet Venture
I need the radio unlock code for a 2000 chevy venture
Ask here for free advice and code (if available)
www.ukbookshelf.co.uk
May 25, 2010 | 2000 Chevrolet Venture
What is the lock code for my 2005 chevy venture radio?
Dont know if this will help but try www.radio-code.com good luck, if not its a trip to the dealership.
Mar 16, 2010 | 2005 Chevrolet Venture
Power door lock on the chevy venture 2000 don't
check the system fuse and or circuit breaker. check the switch wires for damage and loose connections. check the switches for continuity. remove the door panel(s) and check the actuator wiring connections to see if they're loose or damaged. inspect the actuator rods if equipped to make sure they arn't bent or damaged or loose connections. the actuator can ce momentarily. a discernible click indicates that the solenoid is operating properly.
Nov 17, 2009 | 2000 Chevrolet Venture
The radio is lock after battery change. I don't remember the code.
Try 0000 and if that doesn't work you can go to the dealer and they can un lock your radio, call first for the price, if it's a crazy amount, go to www.radio-code.com. They can help you reset your radio for less then the price at the dealer if the dealer has a crazy price. Good luck and hope this helps.
Jun 15, 2009 | 2000 Chevrolet Blazer
How do you reset power sliding door on 2000 chevy venture
there should be information in your owner manual telling you how to do it if you have miss place your owner manual try this website to see if you can down load one for your car its www.edmunds.com and i hope i was able to help you Michigan Man
May 12, 2009 | Chevrolet Venture Cars & Trucks
My radio in my chevy venture reads locked!...I bought the van at an auction....and it already had this problem..how can I fix it?....it is a 2000 model.
Take it by a GM dealer, they can get the unlock code for you!
it's a security feature in the radio.
Please rate well! Thanks!
Feb 28, 2009 | 2000 Chevrolet Venture
Car Audio & Video Logo
417 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
