Question about Thermador CM302U Electric Double Oven
I have a Thermador CM302 every thing apears ok no error codes, but after the oven reaches the temp setpoint the heating element drops out there is no indication that this has happened. The oven is still running convection fan is still running and the display apears normal. This happens on both the lower and upper oven.
  • 9 more comments
  • aircraft7770 Oct 07, 2010
    Is there a way to verify if this board is faulty? I am a controls and HVAC Tech I have all the tools I need to repair this, but I am lacking a service manual.
    Tim is this the Control, power relay power control module Part Number: AP2836641?
    Thanks Bill
    Tim there are two boards a relay control bord pn# AP2836641 and a PC board pn# AP2828582 I beleive you are refering to the relay control board?
    Thanks Bill K
  • aircraft7770 Oct 08, 2010
    Tim Thanks for the info. I checked all the elements and they ohmed OK I will order the board and let you if that works.
    Thanks
    Bill K
  • aircraft7770 Oct 16, 2010
    Tim I just received the new part and it is very different from the old part. The old part has 6 Molex plug on the relay side of the board and the new one all the wires are separate also a few of the plug are different on the new board. Do you know of any parts variations from year to year? Model# CM302BS I cannot locate the SN#.
    There is a number under the Model #, its FD 8608 00077 this unit was made in 2006
    Thanks
  • aircraft7770 Oct 17, 2010
    Tim I just received the new part and it is very different from the old part. The old part has 6 Molex plug on the relay side of the board and the new one all the wires are separate also a few of the plug are different on the new board. Do you know of any parts variations from year to year? Model# CM302BS I cannot locate the SN#. There is a number under the Model #, its FD 8608 00077 this unit was made in 2006 Thanks
  • aircraft7770 Oct 23, 2010
    Tim I just received the correct part and installed and still have the same issue. Any ideas? I know that when using the meat probe when the sensor hits setpoint the oven will stop but this is not stoping. The temp reading will switch from setpoint to actual temp during preheat then it just reads the setpoint on the display after about 10 minutes i will stop and then reset the oven and the temp will have droped 40 degrees but the readout will not change.
    Please help
    Tim, I have returned the first part and ordered a second, the second part is correct. I installed the second part, checked and I still have the same issue any Ideas?
    I will bake something tomorrow and let you know I may have been wrong. I got a different (electronic) temp meter and when set at 200 the temp would drop to 180 before it started to rise. Before it would not come on at all it would be at 200 after 15-20 minutes when the set point was 400 and it had preheated. I thought there would not be this much of a temp swing on this oven. 20F is not a lot but I will check it tomorrow and let you know.
    Bill K
  • aircraft7770 Oct 24, 2010
    Tim I have run the oven and no change set for 400 and now at 325 and droping. What else would cause this?
    President:
  • 2,777 Answers
Wow, that sounds like the control unit of the oven has stopped doing it's job. I believe that model has separate heating elements for each oven, so there is hardly any chance that both could have failed. You will want to replace the control unit / board of this oven.
Thanks
Tim
Posted on Oct 07, 2010
  • 3 more comments
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    Unfortunately not really. The way we would confirm it was bad in a shop would be to just replace the board, if it doesn't fix the problem go to another plan, but I am quite confident it will, and the place I would recommend you get the parts from would allow you to return the board for free for a full refund..
    Thanks
    Tim
  • Tim Grayson
    By the way, that place is here... just select your exact model, the letters stand for the color of the unit, White, Black, Stainless...
    http://www.appliancepartspros.com/partse...
    Tim
  • Tim Grayson
    Yes, sorry meant to specify that, that is definitely it!
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Sounds good, thanks so much!
    Tim
  • Tim Grayson
    Tim Grayson Oct 23, 2010
    Strange, it was definitely the correct part recommended for that system. I am checking on this now. You can definitely return it. If you don't hear from me in the next couple hours please reply back, I am checking on it now for you.
    Tim
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
Thermador cm302 f34 error
upper oven fan airflow switch not activated. It may be stuck or the fan isn't running at all.
Mar 07, 2013 | Thermador CM302U Electric Double Oven
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
Thermador CM302 shuts off intermittently. No error code, timer remains working.
Dear Craig Buck,
This is either a fault with the timer, or you have a fault with the thermostat. Get a multimeter onto that thermostat and test it, after removing the heating element of course. Then get back in touch with me and I will give you the fix.
Yours sincerely
Ouszen
Feb 07, 2012 | Thermador Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
I have a Thermador model CM302 with a built in microwave. The microwave makes all the right noises ... but does not heat the food. What's the problem?
I have the same oven and the same exact problem. The problem is with the magnetron. It needs to be replaced.
Nov 20, 2009 | Thermador Ovens
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
Thermador smw272y won't heat at all
The switches on the first circcuit card mounted horizontally in the space above the microwave enclosure and behind the control pannel have burned to the point that they no longer engage properly to close the power to the oven heating elements. I do not know anyone who has removed the plastic covers and cleaned them to the point of working again properly and do not recommend trying that approach. The only sure solution is to replace the circuit card that has the three switches.
Sep 01, 2009 | Thermador SMW272 Electric Double Oven
Open Questions:
See all Thermador CM302U Electric Double Oven Questions
Thermador CM302U Electric Double Oven Logo
240 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
