Question about APS20B Prestige Keyless Remote Alarm
My keyless remote for toyota highlander wont work, how can i reprogram it?
  • Audiovox Master
  • 625 Answers
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Posted on Oct 09, 2010
Programming a keyless remote for Toyota Highlander 2001
what key color black or grey each color key programs differently.need to know key color.
Jun 12, 2013 | 2003 Toyota Highlander
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
I have 1999 Toyota Highlander with Pursuit Series Model 08SPr remote starter in it. I left the lights on battery ran out. I started car with jump. After that everything works except the remote start. I...
Check the hood pin switch. It's located under the hood around the edge of the engine compartment. It's designed to make contact with the hood when the hood is closed. Also, check for a remote start shutdown toggle switch under the dash.
Jul 20, 2011 | Car APS921 Remote Starter - Keyless Entry
I hear "beep beep" when i press the trunk power button instead of the long single beep. It will not power close neither from the remote or the button on the door. We have to manual close every time. Any...
my friend, i think you need to reprogram your remote keyless entry, find it on your owners manual, or you may go to toyota service center to reset your keys and lock system
Jun 20, 2010 | 2009 Toyota Highlander
I have a toyota highlander (2002). It came with
Open the remotes up...Are the boards the same...?
Jun 12, 2009 | 2002 Toyota Highlander
APS20B Prestige Keyless Remote Alarm Logo
1,142 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
