Question about Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ Wired Controller
I need the driver for my tsz360 pad controller for PC. thank you.
I found this site http://www.roggler.com/rg/index.asp?blogID=56...it helps some but you may have to go in and manually edit .inf file if so just go into device manager find your controller in the dreaded "other devices" section and find your VID and PID numbers and modify the same in xbcd.inf to match. The 360 controller is almost at bottom in the .inf file. I take no credit for any of this except the google searching and modifying my .inf file
Posted on Mar 04, 2011
  • mpire7102 Mar 04, 2011
    Please let me know how poorly i did with the instructions.
How to disable touch pad on hp pavilion ?
you can go to control panel under mouse/touchpad and you can disbale it there , or go to device manager and look for the driver for the touch pad and disable it .
Thank you.
Dennis
Sep 08, 2014 | HP Pavilon xf328 (F5913HRABA) PC Notebook
Tip
Connect A Psx Pad To Pc, Warning soldering is involved..
If you are feeling adventurous ...
If you have a PlayStation and a PC, and do not have a pad for the Computer, or simply those that there are in the market seem to you too expensive or any you don't like, you have a great option here. It connects your PlayStation pad (anyone) to your PC conserving ALL its functionality thanks to the excellent driver DirectPad.
Advantages
It enjoys the ample range of pads that exists mainly for PlayStation and, of its compared price those of PC (speaking in terms quality - price).
They work for all pads including the dual - shock pads. Also, with the dual -shock ones you will be able to use both analog controls and the capacity for "vibrating" (Force Feedback) in Windows games that support it (Need Speed III, Incoming, Star Wars Rouge Squadron, Flight Simulator, Forsaken, etc). If you want to see the complete list of games that support the Force Feedback, look here.
You will be able to use ALL the buttons of PlayStation pad in your preferred games, altogether 10 if you see digitals or 16 of you use the analog control.
You can connect simultaneously up to two pads.
With the dual - shock pads you will be able to change between the digital control to analog during any game session.
If you already have standard PC pad you will be able to use it simultaneously without losing functionality in either of them (if connecting two joystick/pads by a Y connector and to the game port, you will only be able to use 2 buttons in each joystick/pad)
The assembly is not very complicated.
In theory it would have to work with any control system of game for PlayStation (pad of another mark, steering wheel, etc).
Disadvantages
You will only be able to use it in windows games, since driver it is programmed for DirectX.
If you want to use the dual - shock you will need an external power supply, or steal power from inside the computer.
The connection goes to the parallel port, which means that if you are going to use the printer you change connectors... but it is worth the trouble!
Words before beginning
Following with the preliminaries, I will going to make clear that you do not need any knowledge electronics, although knowing how to solder and know how to handle a multi - meter. If you do not have any idea, or don't want to do it get a friend who knows to help you.
on Jan 17, 2010 | Computers & Internet
Doop gamepad driver pc
try to gind the software you needed from CD on internet . download and install it it will fix your problem
Sep 16, 2013 | IGN Entertainment (G60306A) Game Pad
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ??...
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Mar 24, 2011 | Compaq Computers & Internet
The "mouse" pad on my Acer Aspire 5920 laptop has suddenly stopped working. What can I do to mend it
You can try pressing the Fn + F7 key to activate it, if that does not help you can check in the BIOS if the touchpad is disabled.
Thank you for choosing Fixya
Nov 11, 2009 | Acer Aspire 5920-6727 Notebook
HP Pavilion tx 2000 touchpad problems
Ok,The setting for the touch pad are not in the mouse settings,They are in the pen and input settings.
Just go to the control panel and select Pen and Input setting and adjust as needed.
Also with Vista,Windows tries to control everything,so you may need to un install the mouse drivers and allow windows to take control,It will not prevent the touch pad from working,It just stops it from being controlled by the touch pad driver and the windows mouse driver ar the same time.
May 07, 2009 | HP Pavilion TX2000Z Notebook
Need touch pad advice
probably need a driver or at least an updated driver.
Also go into the control panel and see if there is an icon for the touchpad... double-click on that icon and look for settings to enable the scroll pad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Laptop touchpad HELP!!!!
Go to your manufacturer website download driver as per your 'Service tag no.' (which you can find on back of lap).
And install.
But before installation goto Start->control panel -> mouse -> Device Settings and make your touch-pad enabled.
If you got this rightway, then need not to download driver click on ok and enjoy. In other case you have to download driver and re-install it. Before re-installation please un-install the previous driver if you have any.
Thanks
iqbal
Mar 09, 2008 | Computers & Internet
Cod4 on pc
This game does not have controller support, so you must use a 3rd party program. I suggest Xpadder: http://xpadder.com
Download an appropriate profile for your controller, and it works quite well.
Feb 17, 2008 | Microsoft MS Xbox 360 Common Controller...
Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ Wired Controller Logo
4,069 people viewed this question
Top Pelikan Video Game Consoles & Games Experts
James Wishart
Are you a Pelikan Video Game Console and Game Expert? Answer questions, earn points and help others
