Question about Dryers
When the dryer starts it is very noisy for a very long time. It almost sounds like bearing going bad.
Check the barrel inside it must be off site from the roll in the back that it holds it in place.
Posted on Oct 06, 2010
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
How to repair a noisy gas dryer made by speed Queen marathon
its making noise for a reason? bad bearings, bad pully wheels, bad belt? bad tensioner on motor? bad glides on the drum, causing metal to metal? check where sound is coming from then u get a better idea what is the area needing repair
Sep 28, 2014 | Dryers
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
I have a ge dryer model dvl223eb6ww. It has gotten very noisy and sounds like somwthings rubbing or its struggling . any ideas?
Check the belt tensioners pulley for the bearing in the idler pulley does freeze upo causing a thumping sound when they go bad
Jun 15, 2010 | GE DVL223EBWW Electric Dryer
My Fridgedare dryer starts to make a roaring noise at or about 20 minutes into the cycle but does not shut down. I removed the blower-motor assembly and everything turns free. Could this be a bearing...
The bearings get hot and expand causing this noise. You must spin the bearings by hand to feel the roughnees of a rotating bearing that is bad. Take a shick and placing it to the bearings housing will work with your ear at the other end of the stick. It will work just like a stesphscope just like a doctor checking your heartbeat. A noisy bearing will be heard through the stick very clearly while a good bearing will sound running smoothly instead
Apr 21, 2010 | Dryers
When the dryer is running it is really noisey. We should have returned it but didn't
Sounds like something is caught between the drum and dryer (inside) or the drum bearings are going bad. Normally sounds like a squeaking then get to a grinding noise (not good)
Aug 31, 2009 | Dryers
DRYER
you need to replace your drum bearings, you will need to pull the front off the dryer to get to them. They should only run you 6 to 10 each and you have 2 of them. If your handy you can do it on your own. Go to marcone.com with your dryers model # and you will see a diagram of the dryer and be able to order the parts. Good Luck, you can do it!
Jul 15, 2009 | Dryers
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Dryers Logo
Top Dryers Experts
