Question about KitchenAid Dishwashers
My KitchenAid dishwasher model KUDM01TJBS0 has the NORMAL WASH and RINSE ONLY button lights constantly flashing. No other buttons respond. Is this worth fixing?
  • 413 Answers
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Posted on May 29, 2008
The child lock light flash
Hello. Your Kitchenaid unit has the child-lock enabled. Look for a button(or set of buttons) that has a small lock symbol beneath or the word "lock". On most models, you have to push and hold the button(s) until the lock light goes out(usually about 3-5 seconds). That should disable the lock and the unit should operate normally. I hope this helps you!
Dec 18, 2015 | KitchenAid Dishwashers
When start a normal wash, it runs through wash, low rinse, normal, then goes to a non-flashing start auto button.
Hello. Please study the attached photos...the error codes for your model are displayed. Ignore the low rinse aid light. Please let me know if you need further assistance! Thanks!
Nov 29, 2015 | Samsung 24 In. Stainless Steel Dishwasher...
KitchenAid dishwasher KUDM01TJBS0 does not start.
Most likely your keypad is bad. Will need to replace the console.
Nov 20, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The rinse only light flashes
I have no idea about the model number of your appliance, however, the error "Rinse Only" light flashing, indicates that the keypad interface is bad and needs to be replaced.
As the dishwasher detects there is a key pressed and stays pressed, it shows this error. You may want to try pressing each button of the dishwasher to see if by chance it is released.
After some years of use, it's normal that the keypad needs to be replaced because the wear & tear.
Good luck.
Sep 19, 2009 | KitchenAid Dishwashers
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dishwasher KUDS24SEWH?
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Sep 24, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
407 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
