What is the recommended circuit breaker for a 220 volt connection to a 6' baseboard heater
  • 1,420 Answers
Depends upon wattage of baseboard. I would guess about 20 -30 amps. Amps = Watts/Volts. Example, 1500 watts/220 volts = breaker size of 6.8 amps (add 25%) The only breaker available is a 15 amp breaker.
Posted on Oct 06, 2010
How to install two electric baseboard heats together?
Connecting the heaters in parallel means that essentially the two wires coming from the power source (the thermostat) go to the two ends of the first heater, and the same two wires then continue on and are connected to the two ends of the second heater as well. This means that each heater will receive the full 220 volts, and each one will draw the amperage it was designed to in order to reach its maximum temperature. As long as the sum of the two amperages is less than the size of the circuit breaker (20 amps in the case of baseboard heaters), then they both get what they need. If you put too many in parallel on the same circuit, you simply blow the circuit breaker and nothing warms up.
Jan 04, 2012 | Heating & Cooling
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Electric baseboard heater worked last week. but when I
The wall thermostat will click even if there is no power. You will need an electric metere to trace down the problem. May be a bad breaker, bad limit switch or the element could have went bad. You need to follow the electric and see what is interupting the flow.
Nov 12, 2009 | Fahrenheat FBE15002 Baseboard Heater
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
How do I wire up a F2544 baseboard heater with 220 wire?
in a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
What Size Circuit Breaker
a 750 watt heater at 240 volts draws 3.15 amps so a 2 pole 15 breaker with 14/2 wire would be fine
Nov 11, 2007 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
Make sure BOTH fuses on each heater circuit test ok -- they are no doubt 220V -- hence 2 fuses
Nov 08, 2007 | Honeywell (CT62B1015) Baseboard Heater
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
