Question about Brother MFC-9840CDW Laser Printer
Tray one jam - Brother MFC-9840CDW Laser Printer
    Scholar:
  • 107 Answers
Hello, if you have the ability, clean feed roller, try that, if that does not work, then try feeding from mp tray, if that still fails, then the problem will be the entire front door assembly, i have yet to find away to repair, but i do know that replacing the entire front door, does fix the problem.
Posted on Oct 05, 2010
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Brother MFC-9840CDW Laser Printer Logo
126 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
