Question about HP PSC 2355 All-In-One InkJet Printer
I am getting error messages on the screen on the printer. it says Error 0xb9000123 and under that 165:hw_interrupt_hwv2.c What is this and can I fix it?
  • HP Master
  • 7,733 Answers
Hp Support --->link.
Posted on Oct 06, 2010
H-400 error on Sharp 165
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
Drum error code
Hi, drum error codes in digital sharp copiers are non-existent. May be drum error symbols or display messages on touch screen types. They differ depending on model but the most common is reset code 24 sub 7 for example sharp 5015 you rest by pressing; C,Interrupt, 0, Interrupt keys and then inputting the above keys. You may specify your copier model.
Dec 14, 2011 | Sharp Office Equipment & Supplies
When I open my copy machine is a Sharp AR-M355U on the screen appears a message saying code H4-01 What should I do?
H4 error is heat roller under temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-outs on the fuser unit or the fuser lamp is blown.
Jun 21, 2011 | Sharp AR-M355U Copier
Jun 21, 2011 | Sharp AR-M350U Copier
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
I am facing F2-04 error code in sharp AR-M 165
# - interrupt- C - Interrupt -press 16 press Print key then machine is ready.
Feb 12, 2010 | Office Equipment & Supplies
Printer Error Message HP AIO 6210 printer
Hi
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
Riz
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
169 people viewed this question
Seeker5211
Seeker5211
