Partial tv picutre
I have an RCA Tv and the I have a clear picture on the bottom third with distortion on the rest. The sound is fine. Any ideas?
Thanks, Tom
Thanks, the set is a RCA Model F32672SB
Tom
Posted on Oct 16, 2008
  • 4,234 Answers
By distortion do you mean that the top part is stretched? If so, you have bad caps in the vertical circuit. If you are comfortable working inside hte set and can solder, you can fix this yourself. Please post the model number and I can give you the details.
Dan
Posted on May 28, 2008
White box on tv screen
This sounds like your picture in picture feature is enabled or turned on. There is a button on the .ca remote that says pip or you may find it under the menus
Nov 23, 2012 | RCA HD52W59 HDTV Projection Television
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
Distorted picture that curves up at the bottom of the screen
My 9 years old Mitsubishi WS-55857 had the same problem (distorted pictures) for couple of months and I was about to buy a new plasma TV. But, I found TvRepairKits.com and I decided to give a try before buying a new TV. I received a convergence repair kit in two days with web site info for detailed instructions with many picutres to explain the process. When I had questions and Ed was very prompt to answer my questions thru the e-mail. I never done solding before, but I am moderate handy person. I spent less than $100 and three hours and my TV picutre looks stunning. I went thru advanced convergence process after I repalced the convergence chips and replaced RCA video cable with better quality and my TV picture looks as good as brand new. Thansk ED for your help! From Portland Oregon
Feb 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Oct 30, 2008 | RCA P52926 52" Rear Projection Television
Distorted picture on RCA LCD TV
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Oct 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
