Question about Vacuums
Hose won't **** when using attachments- or even without them!
  • 694 Answers
Detach hose from cleaner.
1. Drop a coin or marble in one end of hose and allow it to roll out the other. If it doesn't go through, there's a clog in the hose.
2. Turn on vacuum to check suction at intake (where hose plugs in). If there is suction here, the hose is the problem. If not, check bags and filters, make sure they're new and/or clean, and try again. If it still doesn't ****, there's a possibility of broken fan/s in the vacuum motor/fan assembly.
Posted on Oct 06, 2010
Testimonial: "Thank you, =that was very helpfull."
My kirby heritage II vacuum hose has a cut near the end of the metal nozzle. Is there a way to replace just the hose or even just cut off the damaged section and reattach to the metal nozzle?
We do carry a brand new Heritage II hose here. I do not know how you would cut and reattach the hose without losing hose integrity. You can try submerging the end in warm almost hot water and pulling off the end, cut the hose, and squeeze the end back in. But your hose will be shorter and I am not sure if it will work depending on how it is torn.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Sep 13, 2014 | Kirby Heritage II Vacuum
Why do I have no suction from our EP754C vacuum? Turns on but no suction?
Hi, please check the hose attachment you are using, sometimes tissue paper or fluff can cause the hose to block. You will have to remove any obstruction. Another test will be to check the area where the hose attaches to the vacuum, switch on without hose and use a piece of paper to see if there is suction in this area, if no suction then the problem could be that the inner filter housing the motor needs cleaning. Best of luck.
Jul 23, 2014 | Euro-Pro Shark EP754C Belt 2pk
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
Dyson DC 14 hose has no suction, with or without brush attachments. Hot air shoots out from the base of the canister when I try to use the hose. I cleaned the top filter, but can't figure out how to remove...
It probably needs to be cleaned but, no that is not your problem. You have a clog somewhere most likely. You should take it to your local vac shop to have it serviced and cleaned
Jun 10, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
My steamvac leaks from the clean water tank
try to look for small holes or cracks and even the tank.use clamps to make sure your hose is firmly attached.
Jun 21, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Connecting hoses on Kirby G4
The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
Nov 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
