You will need to double check the motor coupling to ensure it has not broken. You can use the following link to gain access to it:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
If you inspect the coupling and it is intact, your drive motor could be seized or the start capacitor on the motor could be faulty. Let me know what you find. If you need further advice and/or parts information let me know. I hope this helps you.
Ck motor coupling this is the part between motor and transmission they will usually crack or break humming noise or rattling noise or any number of descriptions fit the result
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
hi, the washer fills and drains, but when it attempts to agitate there is a sort of humming noise.
monica
Please elaborate on your symptoms a little more so I can understand how to diagnose correctly.
Does the washer fill, then stop?
Does it fill and make a rattling noise when attempting to agitate?
Does it fill and make a humming noise when attempting to agitate?
Does the washer drain after it fills?
