Question about Maytag Neptune MDE5500AY Electric Dryer
The dryer spins and blows air... but the air is not hot... no matter the setting... Help... I'm a plumber... not a dryer!
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 06, 2010
    Problem Solver:
I agree with the Previous post. If your dryer is not heating. Most of the time people just guess that it is the element. well you have a thermo-cut off kit which is attached to the heater box itself which if one goes out it is best to replace them both.. All 3 can be tested with a multi-meter. make sure all the lint is clear. your dryer can run at 110 but wont heat. I believe it needs to be running at 220. Check your power cord and the terminal block also.. What I see most for replacements is the heater element and the thermostat kit..
Posted on Dec 26, 2010
Air blows hot air all the time
If the actuator is moving when you move the control it may be a broken or warped plastic door. If the actuator does not move look for a bad control unit or a vacuum leak.
Mar 05, 2012 | Mercury Grand Marquis Cars & Trucks
Dryer gets hot. Won't spin.
Sorry to read about your problem, I hope this helps you out.
you have a broken belt, if your unit is not blowing hot air, you then have a defective motor.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Kenmore 62722 Electric Dryer
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
My dryer PYE4557AYW,gets to hot! When U touch below the door??
it sounds as though the heater protection thermostat is stuck closed and wont regulate the heating
May 02, 2009 | Maytag PYE2300AY Electric Dryer
I have a simpson maxidry 326 dryer. It cuts out and stops tumbling after 5-10 minutes,it seems to cool right down and then I have to start it again. So if for instance I put it on the hot setting and say...
Check if the drier is blowing out air from the air duct. If not, the fan pulley is likely broken. With no way to cool the machine the thermostat will be shutting the machine off as it overheats.
Sep 03, 2008 | Dryers
Dryer runs, but no heat.
get corgi registered plumber or whirlpool dont mess, dangerous, telling you problem breaker blowing obviouswly now blown appliance or conversion kit
Sep 20, 2017 | Whirlpool LGR8648 Gas Dryer
Kenmore dryer 110.66812690
kenmore dryer 110.66812690 won't get hot blowing out cold air.
Jan 01, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
463 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
