Question about GE Cooktops
Mod jgp328wec2ww changed orifices from nat to lp. Burners not getting hot enough. It took 12 min to bring 1 qt to boiling and not rooling. how is this adjusted?
  • 494 Answers
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
Posted on Oct 06, 2010
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
How can you tell which fuel a gas cooktop is set up for?
the gas regulator has a round "plug" in the middle of the top and one side is marked nat an one is marked lp you can tell which fuel the regulator is setup for by inspecting this plug. the orifices for the surface burners are marked with thier sizes (.073) for instance which I believe is thousandthsof an inch. also the orifice "spuds" as they are called will often have a drop of colored paint on them to further identify them for installation in the correct burner. checkyour carburation too. if the flame is noisy and trying to shoot up of the burner you could be getting too much air. close the air off a bit till you make a pretty flame two tone blue no yellow.
Aug 09, 2008 | Cooktops
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Burners/Heat
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
Converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Feb 25, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Cooktops Logo
174 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
