Question about Sunbeam 4214 Iron
Sunbeam iron model #4826 leaks water & how do i clean it?
geokohler
  • 304 Answers
SOURCE: clean sunbeam 4045 self cleaning
Make a solution of half water and half white vinegar. Fill up your iron and get is good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
konzzz
  • 255 Answers
SOURCE: Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
Posted on May 29, 2009
  • 158 Answers
SOURCE: sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Posted on Jun 18, 2009
maintenacemi
  • 95 Answers
SOURCE: water leaks
poly seal{white} perished where comes from tank to element plate
Posted on Nov 18, 2009
SOURCE: How do I clean the Sunbeam electric iron, it has a
I found a manual at a different Web Site.
Thank you.
Posted on Dec 07, 2009
Testimonial: "Thank you for responding."
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
Iron was leaking and now stopped working - 2 months old
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 01, 2010 | Sunbeam 4214 Iron
Water leaks from bottom of iron
heatman101
Jun 18, 2009 | Sunbeam Steam Master 4055 Iron
Sunbeam iron won't power up.
Jun 17, 2009 | Sunbeam Irons
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Model #4214 iron doesn't work properly
heatman101
Jan 16, 2009 | Sunbeam 4214 Iron
Sunbeam Iron Leaking Water
"It did not leak." You were misinformed.
Jan 11, 2018 | Irons
Water leaking from iron
heatman101
Feb 06, 2008 | Sunbeam Classic 3964 Iron with Auto...
Sunbeam 4214 Iron Logo
153 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
