Question about Samsung SyncMaster 740N 17" LCD Monitor
Icons are all blurry on the screen (all the time). I tried another monitor and the icons are fine. Can this be fixed.
    Sergeant:
    Champion:
  • 293 Answers
Try to adjust the picture setting like the contrast and brightness.
Posted on Oct 06, 2010
Charging and monitor issues
If your AC Adapter and Power Cord is working fine, then your new battery has a problem if it will not charge. Just because it is new does not mean it will work.
As for your Monitor, try the steps below. Because it works with an external monitor, we know your Video Card is working fine, so the problem is either the LCD Inverter or the Lcd Screen itself is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell XPS 1530-146P (X1530-146P) PC...
My acer aspire laptop 5336-2524 worked fine until today when i turned it on everything works fine except the screen stays black. What can i do to fix this
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 01, 2012 | Computers & Internet
"Out of Range" message appears and the icons are blurry.
Out of range means that you selected the resolution that your monitor does not support.
Your monitor works on 1440 x 900 / 75 Hz.
right click on blank space on desktop and select screen resolution. Put it on 1440x900.
Jun 19, 2010 | Envision G19LWK Monitor
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Dell monitor shows photo and cuser, yet unable to fine start tab or icons. Have reboot 2 times, able to see icons in safe mod only. (note I am send ing this question for my mother in NV, I am in NM on...
Try resetting the monitor back to default settings, If that does not work go to display properties in the control panel and choose the settings tab and adjust the screen resolution. Hope this might help. Good Luck..Darren
Sep 01, 2009 | Computers & Internet
Hp laptop is has docking station connected to acer monitor. The acer monitor has the desktop background but does not show desktop icons. How do I get the icons to show on acer monitor
you will probably find that you have set the screens to run side by side, do a check by clicking the identify monitors, icons will be normaly on the left screen, check the dispay settings and you probably want to set the monitors so they both are showing the same screen at the same time.
good luck.
Jun 30, 2009 | Acer AL2016W 20" LCD Monitor
I bought second hand monitor samsung syncmaster750s..when i plug it the icons become blurry and become large and i cannot set my resolution...i use the vga mode because when i start it normally..it au
Normally if you go in VGA mode the screen will be installed and when rebooting in normal mode it will set itself.
In VGA mode the resolution is 640x480 and you can't set the resolution higher, so what you are experiencing is normal.
From what you are saying it seems that the driver installed from windows is the wrong one, you can try to run windows update to see if there is a driver for it or go on samsung website.
You can get the driver from samsung here :
Samsung 750s driver
If after that it doesn't work check on the internet for compatibility issues with your graphic card, since some of the newer cards can have compatibility issues with the older CRT screens.
Jun 01, 2009 | Samsung Computers & Internet
Acer AL1917A monitor freeze
acer al1917 go blank when change program
Apr 24, 2009 | Acer AL1917AS (Black, Silver) LCD Monitor
Images are blurry. icons, everything
1. remove the monitor dome. adjust the LOT Focus. ( lot top side preset)
2. remove the G4 wire focus ( neck base ) cleen and fixed.
3. replaced the neck base.
4. last and final replaced the lot.
Oct 12, 2008 | ViewSonic G220f (Beige) 21" CRT Monitor
Dell UltraScan P1110 flat-screen monitor BLURRY?
The button you pressed is the reset button and according to the documentaton "returns the monitor to factory defaults".
Here's a link to the Dell support page for your monitor:
http://support.dell.com/support/edocs/monitors/p1110/En/index.htm
Regarding the lines that were orginally were trying to fix; see Damper Wires in Troubleshooting in the above documentation and you'll see that they're a fact of life with this type of monitor. I realize this may not have been your problem, but then again...
I'm surprised that the factory reset made things blurry. Usually this is the result of less than optimum settings on the display adapter in your computer rather than the monitor itself. The Trouble Shooting guide says the brightness and contrast being set too high can cause this so that may be worth checking.
I think you should check your display adapter settings after you try the Troubleshooting suggestions. On the desktop of your computer right click in an empty spot and select Properties. Click on the Settings tab and see what the resolution is. If it's not 1280x1024 you might want to try that. Everything on the screen may suddenly appear smaller so don't be surprised. I would also check the monitor frequency. This will probably be found under Advanced. Every display adapter is different so I can't tell you exactly where to look, just polk around. If you start changing things you may want to write down the original settings so you can at least get back to where you started if there's a problem.
Lastly, I want you to know I'm not paid to provide these suggestions. I know it's a strange hobby, but I like helping when I can. If you find this helpful I hope you'll take a moment and provide a positive rating. About half of the solutions I've posted have never been rated... Thanks and good luck.
Jan 02, 2008 | Computers & Internet
Samsung SyncMaster 740N 17" LCD Monitor Logo
133 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
