Question about Honda Mmd 5000 Watt Electric Start Generator W/ Engine Ngk 6000HE
Honda 5000 generator clear oil out leaking thru air intake
  • 11,896 Answers
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Posted on Oct 05, 2010
Oil leaks from the bottom of the generator. Where could it come from?
bottom of generator would have a small door fastened by two screws tighten the screws to reseal.other gasket known as the front crankcase cover gasket may also leak from underneath check rear shaft seal if front shaft seal is not leaking.
Aug 09, 2014 | Briggs 5000/6200watt stratton Generator...
Honda 5000 generator with remote starter running rough.. tis like ******* or something.. oil was almost empty so i stopped generator and added oil and restarted.. can u give some advice as to how to remedy...
Those generators are set up with a low oil saftey but your gonna want to check compression anyways just to verify it is where it needs to be. Im gonna guess its to be between 120-160 psi, check your manual for the service limits. after that check your air filter, valve lash, fuel filter etc etc.
Mar 29, 2012 | Honda Mmd 5000 Watt Electric Start...
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
My 1990 Honda Accord had a leak into the spark plug area, and also the tube between the pcv and recycled air intake was collapsed shut. I replaced the head gasket and tube. now i'm getting blow by (oil...
The pvc valve will always let some oil out into the intake to burn. That's normal. Now for the misfire at 2000 rpms, I believe you will have to clean out the EGR passages on your intake system. Basically, three of the four individual EGR passages are blocked up and when the EGR opens, it floods only one cylinder with exhaust gas, causing an extremely lean condition and misfire. It's not an easy task to do on that year Accord, but I think it's what's causing the misfire at high rpms, when the EGR valve opens.
Jan 02, 2011 | 1990 Honda Accord
My engine is overheating seriously, what is responsible?
Plugged air filter, plugged exhaust or oil is old or not light enough wait.
Sep 02, 2010 | Honda Mmd 5000 Watt Generator W/ Engine...
Engine runs on choke If I take the choke off the engine will die
The Choke's function is to limit air intake till engine reaches opperating temperature.It should decrease to nill if auto.If not then try increasing the idle.Good Luck.
Sep 17, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Honda Mmd 5000 Watt Electric Start Generator W/  Engine Ngk 6000HE Logo
285 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
