Question about HP (PP036AA) Computer Speakers
I have a Hp Computer HDMI I use to hear the musc and stuff i moved i hear nothing i checked if it was on mute and Volumed up it a computer not laptop and built in compter its not working thank you for your help
    Master:
  • 388 Answers
Check your wireing while checking look closely to see there are no bent pins.
Posted on Oct 05, 2010
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
Cant hear anything.
right click on speaker icon, select play back devices, a box will appear and show the devices that are present, if there is more than one, click on the one that has no green check mark on it. Click set as default and try again. Also make sure nothing is muted.
Mar 19, 2016 | Sony VAIO Computers & Internet
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
I have a Vx2433WM and am using it as a tv for my PS3 through hdmi connection. The audio stopped working. I tried muting and un-muting but nothings happening. How do I get my audio back??
I'd check in the control panel under sounds and see what the system thinks the output device is. Probably not the speakers. If not, change the output to your computer speakers.
Sep 28, 2011 | ViewSonic VX2835wm Monitor
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
My Speakers On My Computer Wont Work But I Can Hear A Buzz Sound?
1st of all click on start->programs-> Accessories->Entertainment->Volume control->options->properties->select Microphone->then click on Mute on microphone. hope this will work
Jun 07, 2009 | Computers & Internet
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
HP (PP036AA) Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
