Question about Konica Minolta magicolor 2480 MF All-In-One Laser Printer
Can the machine still fixable when it just flashes ERROR light and the note that says: CAUTION Machine trouble. Service call (102H). What do I need to do?
    Brigadier General:
  • 10,406 Answers
Telephone the nearest KONICA MINOLTA store, and ask for a service-call, i.e., a technician to come and fix your printer.
Posted on Oct 05, 2010
My Kenmore elite mixer died and the light is flashing but the Motor won't turn on . Is it fixable or no
could be fixable but the repair cost may be more than a new item
have an appliance service center check it out first and then make the decision.
Jul 29, 2015 | Kenmore Washing Machines
Printer is not working. caution machine trouble service call c13851 error display
You really need to call the service centre. The number should be on the printer or in the manual. They make an appointment for the repair with a certified engineer.
Mar 16, 2015 | Office Equipment & Supplies
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
Caution machine trouble call c2558
No such code in the service manual of 4690
Apr 25, 2014 | Konica Minolta Magicolor 4690MF...
Se sente un rumore poi viene la scritta PROBLEMA MECCANICO chiamata assistenza 102H
Replace scanner lamp !!!
Code 102H means that your scannerlamp has not
enough UV light emission.
As it is an Fluotisent lamp it has an limited life span...
Greetz, Robert.
May 17, 2011 | Konica Minolta magicolor 2490MF Laser...
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Jul 16, 2009 | Konica Minolta Di1610 Copier
Spidem Divina - one cup and 2 cup lights flash together
Hi
Caution light usually means something is out of place. Nothing will work until everything is in place and locked.
Steady water light means it needs to be primed, (run water by opening the steam knob). It won't heat until the boilers are primed.
Jun 19, 2009 | Saeco Spidem Divina Deluxe Fully Automatic...
Konica minolta 2490mf service error 102h
Replace the Scanner \ccd Cable pn#1492-1020-01
Aug 06, 2008 | Minolta Color PagePro PS Plus Laser...
Konica Minolta magicolor 2480 MF All-In-One Laser Printer Logo
450 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
