Question about Mitsubishi WS-65819 TV
Projection tv convergence repair. how to fix?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I have start to finish, step by step instructions for this repair in this set.
If you want them rate this help as very helpful and provide mail address and I will forward them to you.
SD TECH
Posted on Oct 05, 2010
  • 1 more comment
  • homemadefrog Oct 18, 2010
    hey would you send those over to me too? Thanks
    soaringchicken@gmail.com
  • SD Tech
    SD Tech Oct 19, 2010
    Fixya does not work in this way. I am happy you liked the solution but what you need to do is post a question of your own, you can in the title mark it ATTENTION SD TECH and if I see it, (I am in California) I will be glad to help you.
    You have several choices--you can post it in the free section or there are several levels where you pay for an answer, in the free sections some experts will bid on this to get you to decide if you want to pay or want a free answer.
    There are rules here which do not want help given to someone who did not actually post the question.
    SD TECH
  • Tim Aug 09, 2011
    This was very helpful. Can I please have the repair instructions? Tass23e@yahoo.com
I have a Sony KP-53HS30 projection TV. The picture is clear for 2 minutes after I turn TV on after that the red color spreads around all light colors on the TV making it unwatchable. Is there a way I can...
Tv have a convergence problems,it dead.The tv convergence board is dead.The tv convergence board,must be replaced like 2 STK convergence ICS and some or all of resistors too.Will fix the tv convergence board,to solved tv convergence picture problems.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.
Mar 14, 2011 | Sony KP-53HS30 53" Rear Projection...
3D look picture in rear projection tv is due to failure of convergence output ICs that will be replaced to fix this problem. If you have no prior experience of electronics stuff repair then local tv repair...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 13, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
I HAVE A DOUBLE VISION, BETWEEN THE GREEN AND RED, THE GREEN IS SOMEWHAT WARPED OR ARCHED.
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Jun 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
The colors don't line up on my projection tv, what
U have convergence prob.it dead.Tries these websites.Tv Repair World.com,Ebay.com to buy a convergence kit,repair what in that kit.U know how to solder right?
Oct 03, 2009 | Hitachi 50FX20B 50" Rear Projection...
Tv out of convergance 300 volts going in 271860 nothing comeing out
convergence out..... repaired 27860 what repaired. do you have the convergence option in setup.. is the piture completely without convergence/
Jul 03, 2008 | RCA HD52W59 HDTV Projection Television
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Picture is green and stays green
check the convergence area for bad solder connection
Sony Convergence
Aug 19, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Mitsubishi WS-65819 TV Logo
274 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
