Question about Akai LCT3201TD 32 in. LCD Television
LCD TV/DVD PLAYER COMBO - DVD WON'T ACCEPT A DISC
My set was purchased just over a year ago(3/30/07) so it's JUST out of warranty. The TV works fine but the DVD player now will not accept a disc. It should pull in the disc when partially inserted but won't. This player has seen very little use and none, recently. I suspected the lack of use made it sluggish to accept the disc, so I pushed the disc into position. The screen indicator still shows "OPEN" not recognizing the disc is in it. I hit play and it ejects the disc. It also rightly ejects it when I hit eject.
Is this a problem encountered by others? Is there a fuse that could disable it like this? Could there be a glitch has occured in the software that I could reset to correct this? PLease respond to Larry Triplett. My e-mail address is greyhound66@peoplepc.com Thank you very much.
Turns out my suspicions wre correct about the DVD player being "sluggish" from lack of use. By continuing to exercise the drive motor by hitting play and eject while simutaneously attempting to insert a disc finally paid off. Now it readily accepts the disc and everything is functioning as designed. Trust me, I'm not going to let it sit idle for anymore extended periods...................baltogas
Posted on May 29, 2008
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I have a 19" LCD
Here's what I would do in your shoes:
1)Try several DVDs, to make sure it isn't an isolated case.
2)Check the firmware version of the TV against the newest one available from Polaroid's website.
3)If you are in warranty, call Polaroid, this is obviously an issue with their TV and will have to offer you options to repair or replace this unit.
I'm sorry you are having trouble with your DVD player.
Jul 18, 2011 | Polaroid Televison & Video
DVD on Curtis LD DVD 199A combo won't work in DVD mode. The DVD won't take or accept the DVD. I have never used the player before today. I did have the label to the back of the unit.
your dvd player wornt play the disk you are playing? Try to consult the region code of the player and the disk you are trying to play make sure they are of the same region..also clean the lens with a cotton buds moistened with an alcohol gently wipe it on the lens.post again if you have further question..
May 24, 2011 | Televison & Video
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
DVD doesnt work
Replace the laser on DVD player and that will resolve your problem. Todays lasers are not that reliable
Nov 29, 2007 | TruTech PLV16260 Television
Akai LCT3201TD 32 in. LCD Television Logo
514 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
