Question about Polaroid A500 Digital Camera
My busy light wont turn off - Polaroid A500 Digital Camera
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
Changed battery trimals and car starts but wont keep running do to secuity light
Best,Genuine and Simple Online business which Really Makes you a Millionaire ! visit :- http://bit.ly/xM9lTH
Feb 20, 2012 | 1993 Jeep Grand Cherokee
Hp Business inkjet 1000 wont stop printing garbage - a bit on lots of paper. It ran out of black ink - now replaced - but now wont stop printing .... Have tried unplugging power and usb. turned...
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Thanks
Till next time!
damnor01
Apr 13, 2011 | HP Business Inkjet 1000 Printer
My brake lights wont turn on when my headlights are on
There is a recall for this condition that may be the problem. The rear tail light assemblies are being replaced because the get distorted from excessive heat causing brake light problems (lights not working, blowing fuses, ect.) The only problem is that Saturn went out of business, so you will have to contact General Motors to see what dealership to go to for recalls. I would start there. It could also be the turn signal switch since the lights go though that first and then to the brake switch.
Hope this helps. Good luck!
Apr 12, 2011 | 2001 Saturn L-Series
My ps3 wont turn on
It should be able to be repaired. It needs a new power supply if it's just not turning on. I have fixed this issue many times (I run a repair business)
I buy mine at http://parts.consolerepairguy.com they run about $35 each.
That place has best prices aside from Hong Kong which I don't trust.
Feb 09, 2010 | Video Game Consoles & Games
Screen wont work and when you shoot it says its "Busy"
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jan 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
After charging on my computer the blue busy light stays on and it wont turn on when i press the power on button.
Easiest solution is to remove the battery and then return the battery back to the battery compartment. Switch on and it will work. Give a feedback if helpful.
Jan 05, 2010 | Jazz JDC87 Digital Camera
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
Polaroid A500 Digital Camera Logo
79 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
