Question about Cozy (W352E) Heater
Have a pilot light, will not fire up - Cozy (W352E) Heater
  • 1,420 Answers
Chances are that the Thermocouple is bad and will need to be replaced. It is found at the pilot assembly and is a copper tube that makes its way back to the gas valve. It is sold at major hardware and farm stores.
Posted on Oct 05, 2010
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
I have a Jandy LITE2 LG325. Only two years old.
Does the pilot light stay light? Or light then go back out? If it is doing that then it is the thermocoupler. looks like a wire that is in the flame of the pilot light. Other than the sparker. That is what dectects that there is fire in the pilot light before it starts the gas. Safety thing. So if that isnt detecting fire, then it will never let the gasvalve open up, Try taking some steel wool or real fine sandpaper and clean up that sensor. The wire. It builds up a thin film on it from gas burning.
May 11, 2010 | Jandy Laars Lt 400,000 Btu Heater
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
Cozy (W352E) Heater Logo
60 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
