Question about Hampton Bay 04078 Avanti Ceiling Fan
Fan works but light just flickers and does not work...
Fan works fine with remote but when I try to turn on the fan light it just flickers a couple times and never turns on. I tried to switch around the TCP#12536Q part from my other ceiling fan which is the same Hampton fan (white with the bowl like light cover that twist off) and the result was the same. What do you think is the problem???? Thank You.
  • rdlasley Aug 12, 2008
    I have the same problem with a Hampton Bay Callaway II 54" ceiling fan. The lights just flicker, but the fan works fine.
  • Anonymous Apr 18, 2009
    Bottom light of Windward III fan flickers and does not turn on - Need to replace the electronic Ballast for that light - that part seems hard to find...
5 Suggested Answers
  • 653 Answers
SOURCE: Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Posted on Mar 01, 2009
  • 139 Answers
SOURCE: hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Posted on Jan 16, 2008
MrARCADIAN
  • 284 Answers
SOURCE: Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Posted on Aug 16, 2008
SOURCE: light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Posted on Mar 28, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
My Harbor Breeze remote control fan no longer responds to my remote controller. The first sign of problems was when the lights began flickering momentarily when I tried to dim them. Then the lights went...
this black box is a watt governor for the lights. just remove it, and wire direct. then you should be fine, just let me know the outcome!! the box should have vent slots in it. part # for hunter fan. i do not know if its the same as harbor breeze. --- part # 98480-02, this is what makes lights flicker. if need be replace remote. go to www.harborfans.com and click on support to find phone number for assistance. have a good day !!
Dec 15, 2010 | Dryers
Lights flicker on and off. Fan works fine
mcdevito75 here, If the wireing in your home / apartment is old and especially if you have an A/C unit or refrigerator on the same circuit as the celing fan lights may flicker with these other appliances going on. --------------- You can also check the wall switch that turns the fan lights on.
Jul 21, 2010 | Hunter 20551 52" Vernazza Ceiling Fan
The light won't turn off with the remote on my Hampton Bay fan
You have problem with the LED Flicker PCB [ printed circuit board ] on your fan . Try to replace the board with another new .
See the pictures to know what i mean : 2e727ba.jpg
Front
Back
I hope this will help .
PLEASE DON'T FORGET TO RATE !
Apr 20, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Fan lights just started blinking, we changed bulbs which were bad but still blinking with new bulbs
This problem was posted on several sites, but this was the only one where I found both the cause of the problem and the solution. Mine is a Hunter 5 Minute Fan which came with no remote. And after about a month the two lights would blink together whenever I'd turn them on at the wall. So in case it helps for that type of fan or the same type of wiring arrangment here is what I did: POSITIVE SIDE: P1) Remove the light shade. P2) Remove the 3 screws that hold the cowel and lower the cowel. P3) Disconnect (pull apart) the black and red wire coupling. P4) Cut the coupling off of the black wire that comes up from the lights. P5) Strip off a quarter inch of jacket from that black wire. P6) Remove the wire nut that connects the black wire coming from the governor with the other black wire. P7) Re-use the wire nut to connect the black wire from step P5 with the other black wire from step P6. NEGATIVE SIDE: N1) Disconnect (pull apart) the white to white wire coupling. N2) Cut the coupling off of the white wire that comes up from the lights. N3) Strip off a quarter inch of jacket from that white wire. N4) Remove the wire nut that connects the white wire coming from the governor with three other white wires. N5) Set the governor aside (or just throw it away). N6) Re-use the wire nut to connect the white wire from step N3 with the other white wires from step N4. That's all, you're pretty much done! Turn on the power and test the light. If all is good, re-install the cowel and the light shade.
Jan 07, 2010 | Hunter Dryers
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay 04078 Avanti Ceiling Fan Logo
598 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Fan Fair Of Boca
Fan Fair Of Boca
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
