Question about Dell Dimension E310 PC Desktop
Usb what do i check for and were????
Need help email me drummernick2002@aol.com live help thx nick
Posted on Jun 08, 2008
Im trying to recovery my music in my hitachi tb, but usb doesnt recognize the device, help
If you PC does not see the drive (assuming the PC has all the required USB drivers), then, 1 check and or subsitute the USB cable. 2. check the power supply/wall wart for correct power. 3. check the USB plug on the PC, try a different one if equiped. 4. the USB interface card in the external case may be toast. You will need to check or sub the interface to ensure that's not the issue. 5. place the drive in a different case with a different USB interface.
Jan 19, 2014 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
Sandisk cruzer blade usb port is not seen in my computer, how can i see it the image of the usb port, the same with the other usb that it is seen
!st thing to check is that your USB Ports are enabled on the system BIOS, and also check if the USB supports the Windows version currently installed in your PC, and also try checking if the USB is detectable in other PC's.
May 27, 2011 | Computers & Internet
The usb port won't work on my acer extensa 4630z laptop
Did you install any Anti virus . Check the USB port for any physical damage. Try connecting a mouse with USB port to check if its working. After all this then the issue remain the same then the USB port needs an replacement.
Regards.
Feb 08, 2010 | Computers & Internet
External HDD is not detected
check the Hdd on a another usb slots uninstall and reinstall the drivers and also check the usb compatibilty if it is 2.0 or not
Nov 05, 2009 | SimpleTech 320GB SimpleDrive External by...
USB taking too long to transfer vista
Note that USB ports (in your computer) and USB devices can either be "USB 1" or "USB 2" speeds.
While "USB 2" to "USB 2" connections are up to 480 Mbits/second,
any "USB 1" to "USB 2", or "USB 1" to "USB 1", connections,
will max-out at only 11 Mbits/second.
So, check that you have a "USB 2" device.
then check that you are connecting to a "USB 2" port on your computer.
Give more details about your computer, and your USB device.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Usb mouse
here is what you can try,
1. try to connect the usb mouse in the other usb ports to check if it works
2. try another usb mouse.
if the usb mouse works in other ports and not in some of them...USB ports gone bad.
if it does not work anywhere, the mouse has gone bad. also to check the usb ports check if keybaord works or not. if yes..its just the mouse. it cost approximately $10. go and get a new one.
Sep 21, 2009 | Computers & Internet
Cant locate USB
check the usb might be corrupted
check it in another system so that u can know the problem.
If the usb is working in another system then check the connection of the wires to the pins of the usb slot
May 07, 2009 | Toshiba 512MB USB 2.0 High-Speed Flash...
My 1T WD usb hard drive no longer recognized
this problem may be for your USB or HDD.
For USB check following: version, if any new windows hotfix installed, if USB port is working.
HDD,
Check if there is any sound in the HDD, no sound is better.
Try to enable USB HDD boot from bios setup and boot with the hdd, check if it recognizes the same
Mar 19, 2009 | Western Digital My Book Essential 1TB...
Dell Dimension E310 PC Desktop Logo
16 people viewed this question
Alun Cox
