Question about Electrolux EI30GF55GS Gas Range
We have lost the burner caps for 4 of the 5 burners and need to replace them. Where do we go to get them quickly before Thanksgiving?
  • 10,865 Answers
Hi. here is the website I use for electrolux parts. http://www.easyapplianceparts.com/Electrolux-Range-Parts.
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Posted on Oct 05, 2010
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
Burner ignighter will not stop clicking. The burner is not lit, but the clicking will not stop
One of the 4 burner control switches on the front of each burner control valves has failed. Inside the thin ceramic switch there are 2 thin strips of copper that are pushed together by a rotating cam driven by the movement of the burner control knob. One of the thin strips is stuck together.
UNPLUG the unit and only plug it in briefly for testing.
The top has to be opened by removing all 4 burner caps and removing the 4 screws under the burner caps. Remove the caps completely but reconnect one burner cap and make sure it is grounded so you can test the igniter's. The gas burner tubing needs removed then the gas burner support has to be removed to gain access to these switches. To remove the wires from the switch you have to use a jewelers screwdriver to release the 2 wires from the switch one at a time. The switches are in series parallel so if one switch is stuck all 4 igniter's pop. To read out the switches you have to remove at least one wire from each switch and insert a short test wire to read for continuity, The switch that has continuity with the burner control switch OFF is the failed switch.
NOTE: the yellow and orange wires need to be insulated during testing. I use a folded paper bag or torn off strips of a cardboard box Just test briefly....
The part number for the switch is 7403P190-60 (Image search)
http://www.repairclinic.com/PartDetail/Switch/7403P190-60/2326
There are numerous sources for the switch.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Magic Chef Ovens
I lost one of my 4 burner cap.I need info about
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 11, 2010 | GE Profile 30" Free-Standing 5 Burner Self...
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
My husband was trying to help clean the controls and broke off the part that holds the control on the cooktop. Can it be replaced? Help . . . need all four burners for Thanksgiving! DCS CT304
You will have to replace the switch if he broke the shaft the knob was on. you can replace the burners just take the burner to your local parts store and show them what you need. on the switch you will need your model number.
Oct 31, 2009 | Cooktops
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Gas range top burners hard to light...
Gas burners use propane or natural gas...refer to the manual to see what it takes and sometimes you have a switch to select the proper gas. you can call a gas man to confirm this and correctly tell you whats going on. but he will propably make a trip. good luck
Aug 31, 2007 | Kitchen Ranges
Gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
Oct 30, 2006 | Miele 36 in. KM342 Gas Cooktop
Electrolux EI30GF55GS Gas Range Logo
123 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
