Question about Fisher and Paykel GWL11 Top Load Washer
Hi, we have an F & P GWL11 with a water leak. Have checked all the basic stuff. Hoses, Inlet solenoid etc. No obvious leaks. Tipped machine over and checked and cannot find source of leak. There is a lot of waterunder machine in the lip of the cabinet when it is laying down????????? Any clues. Thanks. Alan.
  • Fisher and P... Master
  • 713 Answers
Hi Alan.Just read your posting.Now the water on the lip of the cabinet when the machine is laying on its side is from the tank so this will not be the leak.This water on the lip happens every time I tip a machine over on its side.If you have checked the inlet hoses and the black drain hose (when the machine is draining the water) and the inlet solenoids (by removing the top panel and viewing them fill) then I think the only other place is your main tank seal is faulty.Try a wash cycle and after the machine has finished its cycle the look under the machine by leaning it up against the back wall and look towards the center.You will see a round bowl that is colored gray.This is your motor.Now with a torch see if there is any water on it or around it.This should tell you if it is leaking throe the main seal.Has you machine been noisy on the spin cycle?Please reply with additional information on the water on the motor (if any) and whether you have checked all the hoses and solenoids as described.Looking forward to your reply.
Posted on Oct 06, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
My washer pour water just from the back hose ... doesn't suppose to pour water from the right side of the washer ? it used to do so..but not anymore
Hi just read your posting.Now can you tell me where the machine is leaking the water from.Is the water coming out of the black drain hose?Or is the water leaking from the inlet hoses from the taps? Or is it leaking under the machine?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking from bottom of machine however I cannot find a leak when inspecting from the bottom with the machine tilted back. Fisher & Paykel model GWL11. I have not been able to determine when (...
Hi just read your posting.Now have you checked for the leak where the drain hose comes out of the case of the machine? It is located at the back top left of the machine.Have you checked the inlet hoses at the tap end and the machine end?Rub the inlet hoses with your hand from the tap to the machine on both hoses to feel if there is any water on them.Check the nozzle under the lid where the water comes into the machine to see if it is not loose or broken.Please reply and let me know how you got on and If you need further help.Looking forward to your reply.
Sep 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
99 expedition running lean and dying when at idle
Sounds like a vacuum leak. Look for obvious vacuum hoses broken,squished or off. Check at egr valve, dpfe sensor & solenoid. These are all common to go bad. If not obvious take carb cleaner with snorkel attached, spray intake manifold & hoses etc. If idle raises while spraying you located vacuum leak. The propelent in the can temporarily seals leak while its being sprayed. Be careful not to spray on wires or anywhere there is a spark.
Jun 14, 2010 | 1999 Ford Expedition
I have a GWL11 washer that has a small water leak that appears to be clean water. I looked underneath and couldn't see where it was coming from.
Sometimes water can leak from the hoses where they join the taps and/or the water inlet valves..Check for leaks by running you hands along the hoses and unions. Or there may be a problem inside the area behind the display panel...Unplug at wall and remove the 2 screws at rear of display panel. You may have to remove the lid by sliding it upwards while on the open (vertical) position..sometimes the mixer box leaks where the temperature sensor probe connects...Good luck...Nomess
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking into tub of Maytag la9806
Check the solenoids at the valve. Use a multimeter or ohmmeter to check for continuity. A lack of continuity means a bad solenoid. I'll attach a photo for reference. Hope this helped and best wishes.
Sep 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machine always floods after turning on water. There's a leak when i turn on the water.
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the openings on the water inlet valve. Make sure the screens are there and that they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid and the water inlet valve assy will need replaced. I will attach a photo for reference. If this not where the leak is occurring, please let me know. Hope this helped and best wishes.
Sep 07, 2009 | Washing Machines
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
90 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
