Question about Powr Flite PFX1350 Upright Steam Vacuum
My pump blew need a new one which one is it - Powr Flite PFX1350 Upright Steam Vacuum
  • 377 Answers
In the event you do not have a manual, though it sounds like you do, you can find one at this URL:
http://www.powr-flite.com/text/powr_pdf/manuals/extractors/PFX1350_Manual.pdf
The location and telephone number of the company is at the bottom page of the URL. They are located in Ft. Worth, Texas and should be able to provide you with the information and part you need.
If this solution is of help to you, I would appreciate a Thumbs Up.
Be well. Paul
Posted on Oct 05, 2010
Testimonial: "thank you"
  • pwillitz Oct 06, 2010
    I am sorry my solution was of no help to you.
    Thank you very much for your rating. I greatly appreciate it.
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
Shark Steam Mop S3501: Water leaks out but the steam does not reach the pad even with vigorous pumping. The pad mechanism blew off at one point before I realized there was a problem.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Dec 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
BISSELL 1699 :WATER PUMPS THRU HOSE BUT NOT TO FLOOR NOZZLES
Did you blew thru the heater with both hoses off of it? If you did and it was clear, could be the pump, it is just working weakly. Is the top cover flush with the base in the back? If it has broken loose and has risen up, then it won't work. Here is a diagram that may help:
Aug 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
No water or any kind of spray coming out
Could have a bad pump, but first remove the spray nozzles and blew thru them to make sure they are not clogged. Make sure that the gasket is install on the valve on the bottom of the tank and not sitting in the hole where the tank sits.
May 31, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Vacuum cleaner blew the fuse in my house!!
Are you sure that the vacuum motor went bad? If it did, then if would just have to be replace again. Doubt that you would find a different motor other then what belongs in there. If you did it would have to the right size to mount right. Some motors will last a long time while others just don't and you never know how long a one will last. Maybe the power head is what caused your present problem.
Jan 12, 2008 | Vacuums
Bissell Pro Heat gives no flow
Check the heater in the handle to make sure it isn't clogged up where the tubes hook to it. When you put the top back on, make sure the tubes are routed correctly so as not get pinched by the cover. The smart mix valve needs to be on the water setting and make sure that the piston is on the bottom of the smart mix knob. Is the seal at the bottom of the tank on the tank and not sitting in the hole or missing, tha flow indictor cap is leaking air or may even be on too tight.
Oct 17, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Powr Flite PFX1350 Upright Steam Vacuum Logo
147 people viewed this question
Top Powr Flite Vacuums Experts
JoeVacs
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
