I received a broken Philips 42PF7220A37 Plasma TV where the display is distorted as a gift. When I first plugged it in the screen had a black horizontal bar at the top and a bunch of distortions. I opened the TV up and disconnected all the ribbon cables on the 2 buffer boards and then plugged them back in (to make sure nothing was loose). When I did this the horizontal bar went away but I still get a series of distortions. I purchased a service guide for this TV with block diagrams, schematics, and more. I'd be willing to share this with someone that is willing to help. I do not want to blindly start replacing parts. I am hoping I can do some actual troubleshooting to determine what needs to be replaced. I am an experianced electronics test tech and have access to meters, scopes, logic anylizers, and other test equipment. So I am comfortable probing various components. Here is the picture when I first got the TV: http://img411.imageshack.us/img411/4041/dscf6064h.jpg Here it is after I reseated the ribbon cables: http://img96.imageshack.us/img96/7206/dscf6066.jpg I don't know if the change was actually due to reseating the cables or just a coincidence. Originally I was told this TV was producing no picture so maybe it goes through random phases. The last picture has been that way since I did that 2 days ago. Help would be appreciated. Thank you.
  • pawel93 Oct 05, 2010
    Email sent, thanks.
  • 4,889 Answers
It is either the sustain board or one of the buffer boards. Since you have the service manual you should have no problem testing these. Start by checking the capacitors if they read an overload or a value that is below the specified value. Problems like these are caused by voltage drops especially on the sustain boards. There should be two of them X-sus and Y-sus. Ypu should start by testing both of them to zero in on the source of the problem.
Sai.
Posted on Oct 06, 2010
  • 12,061 Answers
Hi please send me the link for the service manual and I'll try and assist you with what to , email the link to silverdragon@gmail.com.. Thanks Chris.
Posted on Oct 05, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
My Philips plasma tv comes on but tv screen is
Contact the authorized service centre for Philips. Especially to Plasma display faults. http://electronicshelponline.blogspot.com/
Oct 15, 2014 | Televison & Video
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
42 PHILIPS PLASMA HDTV 42PF7220A37 Hello, The top half and sometimes the bottom half of the screen would go black now and then, now the bottom half is distorted and theres some issues in the upper half...
Download philips latest firmware here: Click sometimes glitches can be cleared with their firmware. Also this could be a sign that your vertical buffer drivers are over-heating due to a faulty Y-sustain problem. The best way to check is to remove the back cover turn the TV on and see which buffer IC is getting red hot by touching it. Be careful as the voltage levels are dangerous, get someone who's technically proficient to do that little test for you....
http://tvtechwork.webs.com/
Oct 18, 2010 | Televison & Video
Broken screen
if it is limited to external glass the glass can be ordered separately but if there is internal crack on pdp itself would have to replace pdp. from my experience generally if it limited to crack on external glass there still should be picture so there may be additional damage to plasma display itself
Aug 16, 2008 | Philips BDS 4611 46 in. Plasma Television
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Screen frozen
Dec 29, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
New tv
You can go into the menu and adjust the picture setting. If that does not fix the iss and the set is under a year old then it will still be in warranty. Contact Philips at 1-88- 744-5477 and have them do the repairs under warranty. Don't do it your self because that will void your warranty.
Dec 16, 2007 | Philips 42PFP5332D 42 in. Plasma...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
