Question about Maytag HYG2460AWW Gas Dryer
Maytag gas dryer noise when burner comes on
Sometimes, when the gas burner flame comes on, there is a loud buzzing noise that is coming from the burner area of the dryer. It starts as soon as the flame starts and stops as soon as the flame stops. The loud buzzing sound does not occur all of the time but seems to happen more often after the first or second loads are finished (we normally do about 8 loads a week – all on the same day). The noise sounds like some type of actuator or valve noise. I have taken off the front cover and have observed the burner coming on and off with the buzzing noise but just can not pinpoint where it is coming from.
The clothes are dried fine - does not seem to take longer than usual, but it definitely is not doing something right.
  • Anonymous Mar 22, 2009
    Besides the bothersome there any inherent danger w/just letting it go & not repairing it?
    Thanx, Mark
  • 525 Answers
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at
Posted on May 28, 2008
  • David Emmel
    David Emmel May 29, 2008
    Thank you for giving me your rating...I must have missed it yesterday, or maybe I forgot...It's hell getting old...LOL
Maytag gas dryer. Loud buzzing sound when flame comes on. Buzzing stops when gas valve off. Replaced solenoids twice. Dryer works but the buzzing is annoying. Do I need to replace gas valve assembly?
While you are hearing the buzzing, tap the gas valve (gently) to find out whether the buzzing changes. If so, the valve is the culprit.
Feb 18, 2017 | Maytag Dryers
My gas dryer makes a loud buzzing sound when the gas come on how do I fix it?
This noise can be caused by the solenoid valve that controls the gas flow to the burner. If the dryer is not getting hot then the valve needs to be replaced. Depending upon the age and manufacturer the valve may be an integral part of the burner assembly.
May 23, 2015 | Amana Dryers
How do I stop the buzzing noise when in heating cycle?
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
Sep 06, 2012 | Rheem Water Heaters
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
Sep 14, 2011 | Maytag Dryers
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Apr 28, 2009 | Maytag Neptune MDG9700A Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Maytag HYG2460AWW Gas Dryer Logo
347 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
