Question about LG MU-42PZ90V 42 in. Plasma Television
Hi i have a lg plasma tv model# mu-42pz90v and the ysus board is bad. The # on the board is 6871QYH027b and when i put that number in ebay it comes up with several boards with the exact same number and they all look identical in the photos to the one thats in my tv but none of them are listed for use in an LG. There are some that are listed for sony, vizio, and zenith but i cant find any that say they came out of an LG. Will one of these other boards work in my Tv or do I have to wait till an lg specific board is listed
5 Suggested Answers
SOURCE: LG MZ-42PZ14 service manual
Had another plasma the same in for repair so managed to see value on other board!
Managed to find the service manual in workshop but no schem of y susatan.
TV now fixed
Posted on Sep 08, 2008
gsalmen
  • 77 Answers
SOURCE: I have an LG MU-42PM12X tv that is a few years
you part needed has to be for your model of tv.
lg customer service number is 1 800 243 0000
Posted on Aug 05, 2009
virtualhost
  • 2185 Answers
SOURCE: just recieved a lg mu-42pz90v plasma t.v. We got
If your tv came with a remote, make sure sound is not turned to Mute.
Also try to press the DASP button repeatedly to select the appropriate sound setup to "Flat", "Music", "Movie", "Sports" or "User".
You can also do this from the Sound Menu.
Press MENU button and use up and down arrows to select SOUND.
Then press the left [>] button and use up and down button to select desired sound option. Press again left [>] button and up and down buttons to make appropriate adjustments. Press Enter to save.
Make sure cables for audio is also properly plugged to the right port.
Posted on Sep 21, 2009
maatmartin7
  • 1210 Answers
SOURCE: I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Posted on Oct 01, 2009
Hi i have a lg flat screen tv 42px50 want come back on anyone know whats wrong ???
if the standby light stays red when you attempt to switch it on it will be the y sus panel in your tv that needs replaced,,,,it is common on most lg plasma tvs,,,you can purchase a used working one online via ebay or try flattvparts.co.uk just locate the part number on the Ysus panel in your tv which is the larger of the boards on the left side of your tv when you look at it from the rear with the back taken off
Aug 27, 2014 | LG Televison & Video
How do I get Netflix app on my TV
Go to your menu then apps select netflix and sign in thats if your talking about a smart TV
Jun 15, 2014 | LG 6871QYH027B Refurbished Y-Sustain...
Why there is no backlight?
Plasma TV does not use backlight circuits or backlight inverter board. The screen is lit up by PLASMA EFFECT.
You are not getting anything on the screen?
Dec 04, 2010 | LG MU-42PZ90V 42 in. Plasma Television
My TV is less than two years old and out of
this tv needs a new ysus board and maybe the ysus buffer board as well..
type in buffer board for your model of tv in ebay and ysus,, theres a guy there who does them 64.99 & 12 £ postage u muct send your old one in,,for repair / replacement,,
6871QYH053B this is the ysus model u need..
all the best lee..
Apr 28, 2010 | LG 42PX5D 42 in. Plasma HDTV
Lg Plasma PC1DA no Picture??????
The provided description is typical for failure of a YSUS board, which is in turn quite typical for LG 42PC1DA and a bunch of other makes and models which all share the same internals.
To find out whether it's the YSUS or the ZSUS board that has gone bad look at the following article:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
This is for a different make and model, but has the same core modules that 42PC1DA has.
This article also addresses the case when the TV refuses to come on, which is usually caused by a shorted IPM module on a YSUS board which, however, did not lead to burning the fuse as it normally does.
The failure is actually the same, only the symptom is different.
If the failed board is the YSUS (which is the case most of the times, but not always) then you may want to check
http://blog.coppelltvrepair.com/2011/03/how-to-uninstall-6871qyh053b-and.html
Finally, you may consider the following:
http://blog.coppelltvrepair.com/2011/05/should-i-replace-repair-one-or-both.html
Should you need to have one or both boards serviced you can use the following:
http://www.ebay.com/itm/Sustain-6871QYH053B-LG-42PC1DA-REPAIR-EXCHANGE-/110535815308
Apr 12, 2010 | LG 42PC3D 42 in. Plasma Television
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
I have a LG MU-42PZ90V that was given to me. I found one bad fuse. When you turn the power on it flickers from orange to green then shuts off. I was just checking a few things and noticed that it has...
Hi:
On this model you must replace the power supply if the blown fuse was on the power supply, but the main cause for LG failure is the Y_Substain Board assembly. When measureing the voltage of the Large Capacitors, this is the primary side to the main supply, you must measure the caps form hot ground, on the AC side of the Standby transformer for correct Voltage, 66V is to low. Look at the side of the Lrg Capacitors for their voltage ratings, the Supply voltage to these should be some what near this voltage but never higher. The Y_Substain board is to the left of the power supply standing in back of the unit. Its possible its just the Y_Board gone bad, but in my experience the you should replace them both.
Dec 03, 2009 | LG MU-42PZ90V 42 in. Plasma Television
Just recieved a lg mu-42pz90v plasma t.v. We got
Sep 21, 2009 | LG MU-42PZ90V 42 in. Plasma Television
LG 50PX4DR plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Lg 50px4d
LG 42" Plasma TV 42PX3DCV Parts - YSUS ZSUS CTRL Part Number (set): 6871VSNB03E Part Numbers (individual): 6871QYH036D, 6871QZH041B, 6871QCH053G Part Number: 6871QYH036D Description: PCB ASSEMBLY, DISPLAY YSUS ASSY 42V7 FOUND THESE ON THIS: http://cgi.ebay.com/LG-42-Plasma-TV-42PX3DCV-Parts-YSUS-ZSUS-CTRL_W0QQitemZ110086231102QQihZ001QQcategoryZ116199QQcmdZViewItem HOPE IT HELPS
Feb 26, 2007 | LG 50PX4DR 50 in. Plasma TV
LG MU-42PZ90V 42 in. Plasma Television Logo
60 people viewed this question
Computer Repairing
Computer Repairing
