Question about Weber Genesis E-320 Propane Grill
Where can I get the o-ring or seal for the propane hose
  • 10,865 Answers
Hello. This is a common item available at any hardware store. take the hose with you to insure a perfect fit. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Posted on Oct 05, 2010
Replaceing high pressure power steering hose on 1978 chevy trk.where exactly do the o rings go?
On each end of hose, metal ends, just below nut. There is a small indent for the O-rings. Make sure the old O-rings are not still in the pump and gear box fittings.
May 06, 2017 | Cars & Trucks
Where can I find a replacement oring for the regulator end that screws into the grill
Your local propane supplier. They are made of a special material so that propane won't react with it.
Jul 12, 2014 | Coleman Roadtrip Grill LXE 9949-750
I recently installed an Oxygenics PowerSelect hand held showerhead and the water does not come out of the showerhead. The water comes out of the top of the hose instead. I don't know what to do now.
The hose connects to the shower head by a screw on ring. This has a rubber seal inside. unscrew the ring and check that the seal has a ring indentation mark on it where it has been compressed (to form a seal) and the ring mark goes all round, showing a full seal. Make the rubber seal thicker by making a cardboard ring the same size as the seal rubber ring from a cereal box or simila,r and put this on top of the rubber one and reconnect the screw on connection. The extra thick seal may stop the screw on joint leaking.
Dec 08, 2013 | Home
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
I got a new tank on and heater will not ignite. I drained the previous propane tank.
Check to see if the nipple is seated to the tank the o-rings will get hard and prevent a good seal and will not let you tighten up the regulated line to the tank. At work we spray WD40 on these o-rings and this lets us tighten things all the way, also check the tank itself make sure that propane will flow out of the spring loaded ball assembly,(try it on say a gas grill)
Dec 13, 2010 | Heating & Cooling
Which way does the themosat gasket go on a 1997 chevy s10 2.2
Thermostat If It's an O-ring it will go on either way and seal the thermostatic gasket. Removal & Installation 2.2L Engine To Remove:
  1. Drain the cooling system to a level below thermostat
  2. Remove or disconnect the following:
    • Radiator inlet hose clamp and hose
    • Thermostat and O-ring seal
To Install:
  1. Clean and inspect all parts for wear or damage
  2. Clean mating surfaces
  3. Install or connect the following:
    • Thermostat and the O-ring seal
    • Water outlet housing and bolts
      1. Torque to: 89 lb. in. (10 Nm)
    • Upper radiator inlet hose and clamp
  4. Fill with coolant
  5. Inspect for leaks
Jul 29, 2010 | 1997 Chevrolet S-10 Pickup
Propane was leaking between tank and regulator on my BBQ. Replaced with three new regulators and two new propane tanks but still get strong hissing from vent hole and strong smell of propane when I open...
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Jul 29, 2010 | Char-Broil Grilling
I cant seem to get the bbq hot enough to use it unless I use a propane tank and hose attached to the regulator. If I use the small screw in units, it does not get hot enough. using a propane tank and hose...
Most likely not.
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 29, 2010 | Magma Catalina A10-1218 Grill
What would cause ice crystals to form on propane line
Bad hose, bad tank, or seals are gone. Recommenend buying a new tank and new hose. The Ice is from the propane freezing and the hissing noise is a leak from somewhere. Better to replace tank and hose and try again. You do not want to take a chance with propane
Apr 11, 2009 | Weber Genesis Silver B Grill
Weber Genesis E-320  Propane Grill Logo
1,310 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
