Question about Kenmore Dryers
Having trouble getting the heating element assembly back in. Does the housing fit inside the round duct in the back?
    President:
  • 1,554 Answers
Refer to the following pictures:
Indicate the exact model number of the machine for further advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 05, 2010
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
SENSEON DRYER WILL RUN GOOOD FOR 1 OR 2 CYCLES IF STILL WET AND PUT THEM BACK WILL NOT HEAT UP AND DRY THEM WILL GO FROM SENSING TO COOL DOWN THEN WONT DRY ANYTHING
HI,
t normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequentlythere's an obstruction in the vent duct from the dryer to the outsideof the house. For the dryer to heat properly, the duct must be cleanand clear of lint or any other substance.
Heating element Yourdryer's heating element may be partially burned out. If it is, yourdryer still heats, but at such a low temperature that it takes three orfour times as long to dry the clothes. If the element is partiallyburned out, replace it.
Internal ductwork Yourdryer has some internal ductwork. If it gets clogged, your dryer can'tdry properly. In most dryers, to get to the internal ductwork to clearthe clog, you have to substantially disassemble the dryer. A quick wayto check for internal clogs is to remove the lint filter and use aflashlight to inspect the inside of the duct. If it looks clogged andyou can't clear it using your vacuum, contact a qualified appliancerepair technician.
Cycling thermostat Althoughthis isn't a common problem, one of the thermostats that controls thetemperature in your dryer may break and cause the dryer to heat poorly.If so, you need to replace it. The thermostat is usually a small,round, black device mounted to an oblong steel plate. The plate ismounted to the internal ductwork with two screws.
Jul 29, 2008 | Dryers
Heating Element Won't Shut Off
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 26, 2008 | Maytag 24 in. MDBH955AW Built-in...
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
KENMORE GAS DRYER NOT HEATING UP
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Zanussi TC180W Electric Portable Dryer
Trying to replace heating element
its located inside the heater duct assembly on the rear side of the dryer,you need to unplug the unit,remove the rear cover,then remove screw holding the duct after marking and removing any wires attached to the duct and heating element,unscrew the element from the duct assy and reverse procedure to reinstall
Jan 16, 2010 | Maytag MDE308DAYW Electric Dryer
Took back off of whirlpool electric dryer to find where heating element is ocated,, where is it and what do i need to know from there to replace it ???? thank you
Depending on the model. The heating element is inside a piece of ductwork usually in the lower right hand corner of the back of the dryer.
You usually start by taking off the back cover *(which you did) and then you look for a section of round ductwork that has a couple sensors attached as well as wires going down to the bottom where the air enters the duct. The heating element is inside this piece of ductwork.
You need to takes the leads off the two sensors and the heating element first. Then you can remove the duct mounting bracket screw *(this one might need to be reached from the top of the dryer) and then you can slide the heater/duct section off the dryer and look inside to see your heating element. Just look at the element from one end to the other to check for breaks. Order a new element either from your local appliance parts store or get it off of Ebay. They usually are cheap and only take a day or two to arrive by mail.
Good luck and be careful. Always unplug your appliances before attempting any kind of work inside!
Jan 15, 2010 | Whirlpool Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer heats up, but the clothes dont get dry w/o 3 full cycles
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
May 27, 2009 | Dryers
Dryers Logo
153 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
