Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
I have an Hampton Bay ansley 52" fan with light. How many wires should be coming out of top of fan.
  • 377 Answers
The answer to your question can be found at this URL:
http://0000lx5.previewcoxhosting.com/manuals_fans.htm
For some reason I could not bring up the Ansley unit, but I think you will find the only difference in general is the size and shape. As long as you fan has a fan, lamps, and a remote control, the wiring should be the same.
In general a fan with lamps will have three wires coming out the top when used with a remote control: White - Circuit neutral Green or bare wire - Equipment ground, the third plug we have to deal with on many tools, etc, an inconvenience but an important safety device of sorts. Black or Red, etc - Power into the fan.
If the fan and lamps are to controlled independently of each other, there may be more wires coming out for connection to wall switches.
Important note - If you are installing a fan in this ceiling box for the first time, there are requirements for special fan rated ceiling boxes in order to be able to hold the weight of the fan and many municipalities require permits for ceiling fan installations - boiler plate CYA.
If you find this solution helpful, I would appreciate a Thumbs Up from you. If you require additional clarification, please contact me.
Be well. Paul
Posted on Oct 05, 2010
  • pwillitz Oct 06, 2010
    I am sorry my solution was of no help to you.
Ansley 52 " won't work
Probably needs a new receiver. That's what you get when you buy a low-end store brand.
Apr 13, 2014 | Hampton Bay Dryers
I have a Hampton Bay fan and light fixture. The fan works using the switch., the lights do not come on at all, withe either the pull chain, or the remote. There is continuity from the source to the...
You might check to see if the blue wire is connected on top in the canopy and check if you have voltage coming out to your light kit at the wire connection with a meter. Careful with the power.
Aug 25, 2011 | Hampton Bay 52 In. White Redington...
Do you have free manuals for a hampton bay ceiling fan model 52 rdt?
http://www.homedepot.com/catalog/pdfimages/c6/c640c29e-5efd-4045-be74-016e88d7e04b.pdf
According to Home Depot this is the Hampton Bay manual for that model number.
Indicated here: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&productId=100032172&R=100032172
Excerpt:
  • MFG Brand Name : Hampton Bay
  • MFG Model # : HD302243
  • MFG Part # : YG092-VPW
Jun 05, 2011 | Hampton Bay YG092-VPW 52'' Preston Vintage...
How do you install the remote transmitter in a Hampton Bay Ansley ceiling fan?
jaggirl, most Hampton Bay, Remote Controlled Ceiling Fans have the receiver already installed inside the fan's cowl. The Transmitter is the Hand Held Remote. Both require batteries.
Apr 05, 2011 | Air Purifiers
Ceiling fans turn themselves on.
Hello :
I don't want to scare you . But when your fans turn themselves on , that means there's someone else at home . Why I'm saying that ? It seems that you have a problem in home electrical wiring connections . You need to make test . You can stay in the room where are the fans and send someone else the turn on switches at home one after another until you find which switch is turning the fans on . You need an Electrician to correct this error at home and to wibe ghosts out .
good luck .
rate please .
Mar 20, 2010 | Hampton Bay 52 In.Carriage House II in...
After installation fan and light will not work
Did you make sure the wire nuts were tight in the fan and in the box? Is there a switch controlling this fan?
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
361 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
