Question about Trendnet TEW652BRP 300 Mbps WiFi N router (710931600391)
Router does not read my IP address - Trendnet TEW652BRP 300 Mbps WiFi N router (710931600391)
  • Trendnet Master
  • 7,733 Answers
Go to Trednet Support ->link.
Posted on Oct 06, 2010
5 Suggested Answers
  • 38 Answers
SOURCE: router unable to acquire ip address
logon into your router through n/w interface first (ethernet not wireless) using the default IP assignment of the router. Now you can manually assign an I/P to it.
Posted on Oct 09, 2007
Cameron07
  • 110 Answers
SOURCE: change ip address of recently installed router
The 192.168.0.1 is the device IP.
Your trying to change the "Default Gateway" mine is set to 192.168.1.1
Let me explain (:
1.Go to start>run>type "cmd" without quotes and press enter.
The black screen should appar, in that screen type "ipconfig/all" without quotes.
And press enter.
This is what mine looks like:
I took out some things to my security, but basically this is what some of these things represent.
For you, your IP it shows would be something like:
192.168.1.101
Each device hooked up to your network gets its own IP it will start at 192.168.1.101 for the first device, then 192.168.1.102 then the next device gets 192.168.1.103,etc...
Your default gateway, 192.168.1.1 is where it starts, to change this go to:
  1. Open your browser
  2. Type in the browser 192.168.1.1
  3. Login to your router panel (the user an pass sometimes are admin/admin look in your manul for more info)
  4. Look where you can change your default gateway.
Here is a example of what mine looks like:
I hope this educated you, and helped you fix your problem for more help visit www.pc-fix.us or just reply here.
Thanks,
Cam
Posted on Oct 18, 2007
SOURCE: dynex e401 router
if u r using modem make syre that modem is in bridge mode .. and dhcp server is off on modem .. then connect the router and configure the router acc its type i.e dhcp or pppoe .. bali
Posted on Nov 29, 2007
  • 5 Answers
SOURCE: I cannot connect to the router. The IP address
try using http://192.168.0.1 or go to http://www.ncsu.edu/resnet/wireless/netgear/netgear_mr814v2.php
Posted on Aug 13, 2009
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
I cannot access ip address from internet explorer (dlink 615) to access the security settings and lock router.
Verify that you are typing in the proper IP address. To do this you must:
1.Open a command prompt window
2. Type "ipconfig /all" without the quotes
3. You will see an IP Adress field. It should read 192.168.0.x or something sililar*
4. The address for the router will then be xxx.xxx.xxx.1 where x is the rest of the address you see in the field.
*note if your IP address reads "169.254.xxx.xxx", you have a connectivity issue of some sort. Check your cables/power.
Oct 29, 2010 | Computers & Internet
Is the the router No 191.168..1.1
Hi Thanks for your question
Default routers IP would be 192.168.1.1 although this may vary! To be sure you choose the right one you need to do this. Press
Start--->Run--->
In run box put "cmd" (without the quotation marks) This should open you a command prompt Put "ipconfig" and press enter. You will be showed your current ip configuration. The address that your after is the "default gateway" this will be your router IP. For more about routers and accessing settings please read this http://www.fixya.com/support/r4695161-change_wireless_network_password_forgott.
I hope this helps Good luck
May 11, 2010 | Linksys WAG200G Router
How to set the ip address of routers
IP address on router are set in default. Commonly used 192.168.1.1 default on firmware.
IF you wanted to use another IP address just open the router firmware in IE or Internet Explorer.
Read the instructions before you configure it.
Nov 01, 2009 | Linksys Wireless-G WRT54GS Router...
My ip address should be 192.168.1.1 in the setup tab inlynksis but isn;t how do i change it manually
The default IP address of the Linksys router is 192.168.1.1.
First check the IP address of your computer.
START ==> RUN ==> type cme and hit OK==> you will find the command prompt. Type " ipconfig " in the command prompt and hit ENTER.
Now you will find the IP address and the Default.
Default Gateway is the IP address of your router. with this number you can open the set up interface of the router. and change the IP address of your router.
For more info about networking Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
HOW DO I GET IP ADDRESS FROM MY ROUTER AND HOW DO
the IP address for you router is usually 192.168.0.1
anyway, you can get it following these steps:
go to start -> run, and type "cmd" (without the quotes) and press enter.
then write "ipconfig" (again, without quotes) and hit enter. read the information provided and right next to "Default Gateway" will be your router's IP address.
if you have never changed the password, you should use the default one:
user: admin
password: password
Aug 28, 2009 | NetGear RangeMax WPN824 Router
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Feb 02, 2009 | Arris SURFboard SBG900 Wireless Router...
Can I reset the address of the router?
wire a computer directly with ypor router.
Have contact? if Yes you can read the IP adress within your operating software.
READ!!
Connecting two routers to each other is not difficult but is a lot more work than only changing the IP address. Firewall/ DHCP and other settings have to be changed on both routers. You need to look this up in the manuals of your routers.
Hope to have helped you.
Pascal
Jan 23, 2008 | Asante (99-00618-71) Router
Trendnet TEW652BRP 300 Mbps WiFi N router (710931600391) Logo
65 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
