Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Where can I order replacement baskets for my Kitchenaid Superbra refrigerator (model #KSC5251)?
  • KitchenAid Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 08, 2010
How do you take off the ice/water panel on the front door of the freezer to make repairs?
YOU WILL MOST LIKELY NEED AN ICE DOOR KIT, THE EARS OF THE ICE DOOR BRACKET ARE BROKEN MOST LIKELY,
Jul 27, 2012 | KitchenAid Refrigerators
Does not make ice
look inside the tray their should be an metal arm that may be stuck due to ice build up
Apr 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
Replace wire baskets in freezer, the model I purchased only has wire shelves. However, in the store i tried the baskets from the GE Adora 29 cu ft and they worked fine.
Get the actual model number from the refrigerator with the baskets. Then go to the Sears parts website at www.searspartsdirect.com. They have exploded views and parts available for a lot of appliances, and you should be able to get the part number and price for replacement baskets. Once you have a part number, you can do a Google search for that number to locate other suppliers and shop around for a good price. Or you can just check at the store where you purchased the refrigerator about ordering the baskets right through them.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid superbra 24 oven
select clean on the control panel and set stop time then push start
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superbra Freezer Settings model ksrs25qf00
21/2,will give you 0 to 8 degrees,the hiher you set the dial the cooler it gets in the freezer-mike
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
97 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
